TTClamps Audio clamps?
ViperZ
Has anybody heard about this manufacturer?
They are local, so would be pretty easy for me to get.
http://cgi.ebay.ca/TTWeight-Record-Clamp-Weight-Style-1LB-454-Grams_W0QQitemZ330335030991
Thanks!
Thanks!
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
B&W CDM1-SE fronts
B&W CDM-CNT center
Post edited by ViperZ on
Nice review and thank you for sharing!
Could you tell me why you went with the weight rather than clamp?
I am comparing this weight: http://www.ttweights.com/catalog/item/6997332/7020312.htm
with these clamps:
http://www.ttweights.com/catalog/item/6984492/6999408.htm
http://www.ttweights.com/catalog/item/6984492/6999370.htm
Why does weight make a difference in the *clamp*?
Thanks!Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
TTWeight customer service recommended the Weight for my particular TT. They said the clamps were more designed for VPI tables. Ask them, they have a good knowledge of TTs.
If you are not going the route SS went then you are better off buying this clamp;
http://store.acousticsounds.com/d/36249/Clearaudio-Twister_Clamp-Record_Mats_and_Clamps
It is a reflex clamp designed much like my own. It will work on all turntables and will also remove warps. If you do decide to get one, I'll give you some shims that will help stregthen the reflex action.
Joe -
Joe, thank you very much for the offer. One of the main reasons why I am looking at TTWeights clamps is that they are in the same city as me (so free shipping, no duty charged over-the-border, etc.).Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
That must be a real bummer in Canada when trying to buy something from the US . . . duty charges, higher shipping costs, customs etc.
You can't got wrong with TTWeights. I hear their platter works out well too. As far as clamping goes, Clearaudio makes a great product as suggested by HI, but I personally don't think anything can be as effective as a good outer ring. You'll pay extra, but you'll notice a massive difference in your vinyl with the outer ring. IT flattened all my LPs out perfectly.
I think you might be right in most cases of central clamps and weights. With one notable exception, none I have tried really flatten records effectively by themselves.
The exception Is Joe's Clamp. This is one reflex clamp that is really designed well. In this case I am not so sure about the advantage of a ring weight, apart from the added benefit of the flywheel effect. See the thread I started on this topic.
Unfortunately the Clamp is now largely unobtainium. I have not tried the Clearaudio Twister that Joe recommends but it does incorporate at least some of the features of his own design.
I have not tried the TTweights products either, but they seem fairly priced and they get consistently good reviews and comments.
Another possibility to consider is the URSR ring weight designed by Rudolf Bruil. This one incororates some damping in the ring itself. It would be more expensive to get than the TTWeights rings and clamps.
Cheers,
Ian -
I'm a believer in clamps. I plan on picking up a one of these as soon as I get the Rega arm installed on the Empire 298 that arrived tonight.
http://cgi.ebay.ca/TTMicro-Turntable-Mat-1760-Gram-Copper-4-lbs_W0QQitemZ330335065876QQcmdZViewItemQQptZLH_DefaultDomain_2?hash=item4ce9811714&_trksid=p3911.c0.m14#ht_1022wt_999
That's about ~3.5 pounds, me buckos. But with the bearing on this Empire, it should spin up pretty easily. The platter and clamp on it now already weight about 7 pounds, and it all spins up very smoothly with just the polymer belt.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
One more question...
Dual 1228 TT has a removable spindle... Well, it comes with 2 spindles - the short one for single record play and a long one for record-changer option.
So, does it mean that the *clamp* will not work with my spindle, since it might just pull the spindle out.
Should I just go (am I stick with) the weight type clamps/weights? Thanks!Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
hearingimpared wrote: »If you are not going the route SS went then you are better off buying this clamp;
Joe
+1, I took Joe's recommendation on this and have not looked back. Adding his washers helped as well.
Thanks again, Joe !Speakers: SDA-1C (most all the goodies)
Like I said, my spindle is not fixed, thus I think I am stuck with the weight-style "clamps"...
B&W CDM1-SE fronts
B&W CDM-CNT center
Viper I believe you are correct in your thinking. A reflex clamp would probably pull the spindle right up and out although I believe there is a 30 day money back gurantee on the "twister" clamp so it would be worth a try.
hearingimpared wrote: »Viper I believe you are correct in your thinking. A reflex clamp would probably pull the spindle right up and out although I believe there is a 30 day money back gurantee on the "twister" clamp so it would be worth a try.
Do you really believe that the weight-style clamp would make a difference? i.e. would it really flatten the record?
I understand how the real clamp works, and it definitely makes sense, but I am not sure if the weight will help and how much weight will I need. There is 1 lb and I believe 2 kg weights available from TTWeights. My TT is belt-driven, but I am sure (hope?) that the motor/belt will be able to handle extra 2 kg...Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
If nothing else it will stabilize the record and there is nothing wrong with having to give your platter a little help in starting to spin.
What did you decide on?
LOL, forgot about this thread.
I talked to the TTWeights owner for quite a bit, and we decided on this one:
It's 1 lb weight (not clamp). 1 lb is good enough to mostly flatten the records, but not bottom out the suspension in my Dual 1228 TT.
I cannot say that I hear a significant improvement in sound, but I haven't used my TT much since buying this weight (was busy with work and winterizing my bike). The records are visibly flattened and it looks nice
B&W CDM1-SE fronts
B&W CDM-CNT center
Do they recommend a particular mat? Seems like the weight-only approach would work better with some vs others.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I haven't asked them about the mat. Since I was limited to weight-only approach, my only concern would be to pick a weight, which would not bottom-out the TT suspension. So I could not pick anything over 1lb.
Regarding the mat, i am currently using Rega "replacement" mat and pretty happy with it. It's made out of some soft material, which seems to remove some static from the records (old Dual rubber mat bit the dust a while ago).Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
That is a nice looking stabilizer.
