Upgrade Pattern, Changed again - good move or bad?
VR3
VR3 Posts: 29,400
I've decided to not upgrade my cables, as I don't want to venture into it just incase it is better. Just for that fact, I don't want better right now as I would have to upgrade everything......
Anyways
1) SVS PB2 ISD
2) Replace RT35i Tweeter
3) Surround Shelves
4) (1) 12 Foot A/V Cable, (1) 12 foot Patch Cable
5) XBox
6) Controllers and Games
Then I will start my XBox hobby. I am not worried about a center channel right now...I don't watch enough movies to give a flying....
How does it sound to you guys?
I should have this completed by August 2004 - That is IF I work that summer, which I hope to. I will be running 2 Jobs that summer...
    VR3 Posts: 29,400
    edited September 2003
    Would HD wire hold off for Surround wire???
  • organ
    organ Posts: 4,969
    Looks good Sid. As long as your wires are of sufficient gauge with no oxydation, you should be fine. I'm in the same boat as you. I'm not planning on getting better wires yet. So far my Monster 12ga is doing a fine job. But like everything else in this hobby, things could change overnight:).
    Maurice
    VR3 Posts: 29,400
    Well I have like 300 feet of HD, that is why I asked....lol! It works fine for me, but I noticed a difference in the mains, but I just can't see the benefit for the surrounds, sounds like a waste of wire to me......
  • dcarlson
    dcarlson Posts: 1,740
    Sid, whenever you're ready wire. ;) Why an Xbox and not a PS2?
    Wire runs to your mains can be a relatively cheap upgrade as opposed to a component. I have a pair of 8 foot runs at $4CDN/foot of Kimber 4vs. I run some Wallmart special wire for surrounds, it was the cheapest I could find.
    Personally, my wallet can't justify the cost of higher grade wire to my surrounds.
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
    VR3 Posts: 29,400
    I don't like the PS2.
    I would state why, but a war is not what I want to start....lol
  • dcarlson
    I meant nothing by it. I was just curious. :)
  • Shizelbs
    Shizelbs Posts: 7,433
    Are you planning on modding your Xbox?
    VR3 Posts: 29,400
    No, I don't know how....lol.....what do you mean.....Mod? Change what on it? Parts? Looks (other than that big black ugly arse box)
