rt2000i vs rti150 ?
steelervic
Depends on what amp you are driving the 150s with. If it's just a receiver in the 100 watt per channel range (or less), I'd say the 2000s. If you have a seperate power amp of at least about 200 (or preferably even more than that) watts per channel, then I'd say the 150s hands down. That is on the bass aspect of it. As far as the tweeters go, it's no contest, the 150s by a landslide!
I love the 2000's and think the tri-lam sounds better. Just my opinion. I would definitely look at the power source. Like Bigsexy suggests, you need alot of power to drive the 150's. The 2000's are much less dependant on obscene amounts of power.
If you can, listen to them both, because you know the old saying about opinions.
Good luck
Rick
