help for wiring speakers
Hi,
I am a newbie at this so please help. I have the Tsi 500s and it has 4 binding posts. Do I need to wire the 4 posts with a jumper or biwire it to get the best possible sound. Some say the first binding post is for the tweeter. Any information on it would be helpful and also any directions that I need to follow to bi-wire it would be great.
thanks,
dvd
thanks,
dvd
Post edited by dvd_rw on
If you biwire meaning you will use all 4 binding posts, you most take out the jumpers connecting the 2 sets of binding post, if you use a single speaker cable then keep the jumper in place.
Biwire might and might not have any impact on your system, This is something you must decide on your own having you listening to your own speakers with your own equipment.Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire -
This link can help:Hi,
thanks,
dvd
http://www.audioholics.com/education...to-loudspeaker
http://www.audioholics.com/education/cables/
Note:
You can exploit this advantage by using oxygen-free cables and the sound will be very satisfactory. -
Simple diagram for you.....
http://www.brilliancehifi.co.uk/how-to-bi-wire-speakers.htm
You can also buy, bi wire speaker cables. They will have 2 terminations on the amp end and 4 on the speaker end. Shown here from Signal Cable.
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
