Looking for wall brackets to hold TSi200
I want to make something like this but I dont know what brackets need (Because is a little big for a wall)
I need a little of help
TV: Sony KDL-32LL150
Front: Monitor 50 | Monitor CS1
Center: Monitor 50
Rear: Monitor 30
Control: Sony RM-VL600
Receiver: Sony STR-DG510 5.1
HTPC
Case Armor+ Mx
Logitech Mx Air Mouse
Phenom 9950
Asus M3AT8-EM
OCZ ModXStream 600W
OCZ 6400 2GB
WD 500GB
Center: Monitor 50
Rear: Monitor 30
HTPC
Case Armor+ Mx
Phenom 9950
Asus M3AT8-EM
OCZ ModXStream 600W
OCZ 6400 2GB
WD 500GB
Post edited by Luiquroj on
Welcome to Club Polk!
Not sure if youre looking for a smaller bracket is it? Anyway if that is what youre looking for then disregard my link but heres something Id recommend for them.
http://www.crutchfield.com/p_121BT77B/B-Tech-BT77-Black.html?search=bracketTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
That bracket in the OP's picture is a B-Tech - BT-77. I use them for my LSi7's as well.
What are you trying to make? A clone version? What do you need different that the B-Tech won't do? Do you plan to make it out of metal or wood?
Welcome to Club Polk....
Thanks for the welcome
I am searching only a bracket that can support the weight and I can move from left to right, I hear suggestionsHome Theater
Center: Monitor 50
Rear: Monitor 30
HTPC
Case Armor+ Mx
Phenom 9950
Asus M3AT8-EM
OCZ ModXStream 600W
OCZ 6400 2GB
WD 500GB -
For that, the B-Tech is the way to go. Works great. (it is a little expensive though)Mains.............Polk LSi15 (Cherry)
The link I posted for the brackets support a weight of 55lbs, the TSI200's weigh in at 17lbs so they'll easily hold them up...even checked out the dimensions too.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Mmm but I need make some holes to the speakers right?
I want to use them as a surround speakers and put the TSI300 and cs10 as frontal/center speakers
The only thing that I still dont know is what subwoofer I will buy =P
I dont want to spend more to $140-$200 in this because I need made International shippingHome Theater
Center: Monitor 50
Rear: Monitor 30
HTPC
Case Armor+ Mx
Phenom 9950
Asus M3AT8-EM
OCZ ModXStream 600W
OCZ 6400 2GB
WD 500GB -
Please don't put holes in your speakers. You can use fishing line to hold them to the stand or do something like this.... .
(its what I do)
No, the brackets have adjustable "side grips" to hold the speaker firmly in place...no need to drill anything into the speaker itself. Just your wall to mount the wallmount to.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
xDD, that is what I dont want make, little holes everywhere. Thanks both, I will buy a pair of this bracketsHome Theater
Center: Monitor 50
Rear: Monitor 30
HTPC
Case Armor+ Mx
Phenom 9950
Asus M3AT8-EM
OCZ ModXStream 600W
OCZ 6400 2GB
WD 500GB -
Definably do something like Michael did !!! (nice instructions, btw)
Several reviewers on the Cruchfield site did not and found their speakers on the floor.
