Stupid question - attaching pictures
I would love to post some pictures of my final setup of my HT system, just don't know how to do it on polk's site. Any help would be appreciated. Thanks.
Hank
Hank
My 7.1 System:
Fronts: Polk RTi70's
Center: Polk CSi40
Surround Sides: Polk FXi50's
Surround Backs: Polk RTi38's
Sub: SVS PB1-ISD
Receiver: Sony STR-DA7ES
SAT Receiver: Sony SAT 200B
HDTV: Panasonic CT-36HX42
Center: Polk CSi40
Sub: SVS PB1-ISD
Post edited by hank1105 on
When you're writing a post, there is an Attach File box below the text box. You put the address of the photo in there. It has to be either a gif jpg png txt zip bmp jpeg doc file to work.
Let's see how this works:My 7.1 System:
Center: Polk CSi40
Sub: SVS PB1-ISD
HDTV: Panasonic CT-36HX42 -
Guess not, odd, lets try again:
Do you have to put in the link address (URL)? Or can you just browse to where your images are kept on your local computer and just attach them to the post? I have tried to browse, found the file, it is under the 100k limit, but it will not attach.
Again sorry for the NEWB question.
HankMy 7.1 System:
Center: Polk CSi40
Sub: SVS PB1-ISD
if you want to post a pic that is on the web then click on the IMG button in the reply area and paste the URL in the window that pops up, if you're attaching a pic from your computer do as burdette instructed.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
Hank
Make sure you don't preview your reply. If you do, the pic doesn't attach. -
That must have been it, I previewed my picture, let's see here:My 7.1 System:
Center: Polk CSi40
Sub: SVS PB1-ISD
Well that worked, thanks for the replies. Just have to resize it next time
My 7.1 System:
Center: Polk CSi40
Sub: SVS PB1-ISD
