Need help with dry walls
izafar
izafar Posts: 819
Due to a very unreasonable increase in the APT Rent, I have decided to move another one (which is cheaper and better then my current one!). The issue is I have many holes in the walls where I placed screws for hanging speakers, photo frames etc. I wanna know is there a way I can fix those holes so that they are not noticable when I move out. I simply dont wanna pay $10 per hole as damage charges.
Any help from the DIY guys will be appreciated.
-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2003
    DAP makes some great spackling, it is pink when applied to the holes, and dries white. That way you know its good to go. Use a plastic or metal putty knife.
    Management usually means large holes, not picture holes. I always spackle everything, just so they have no excuse. As long as you spackle, and then perhaps some light sanding with a cheap sandpaper sponge, you should be fine. That is more than most people do anyways. They are going to repaint anyhow.
    Good luck in the new apartment. :)
  • tryrrthg
    tryrrthg Posts: 1,896
    edited August 2003
    They make some putty that you can fill in the holes. Just go to home depot or I got mine at Wal Mart. works like a charm. if you really want to keep it cheap I've been told white toothpaste will work too, it just won't get hard.
  • hoosier21
    hoosier21 Posts: 4,415
    edited August 2003
    holes from hanging pictures and such should fall under normal use/wear or whatever, and should not bring any charges (unless your landlord is a total ****) For these holes go to Home Depot, that have a hole filler that comes in a squeeze tube, and is marked "no sanding" or something like that.
    how big are your holes from the screws? if they are larger than say a pencil, you will need to get Lightweight Spackling Compound and fil in the hole with a putty knife, if you are good you can apply it and not even have to sand.
    Good Luck
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • burdette
    burdette Posts: 1,194
    edited August 2003
    Go to Lowe's or HD or wherever and get some ... well.. there will be several different products that will work, but "spackling" is sort of the generic name. Here are examples:
    http://www.gesealants.com/sealants/residential/portfolio/other/gespackling.shtml
    http://doityourself.com/store/spackling.htm
    The procedure will depend on the size of the holes. If they're large holes, don't try to fill it all at once out to the surface of the wall.. you'll have to fill it some, let it dry, do it again. Some of the products are pretty gooey and they'll 'bulge' out and down, so again, don't try to fill all at once. Some products are drier. You'll just have to experiment with whatever you buy.
    If the walls are textured, i.e. bumpy, you can try to match the texture my mixing something into the final coat of spackle. You could use a little sand or some tiny pieces of shredded styrofoam.. again.. you'll have to try things out. Don't glop it on or you'll end up with as big an eyesore as the hole. The point is to have the final, dried, layer of spackle at the same 'level' as the rest of the wall.
    If they are REALLY big holes, i.e. 'damage'.. you may have to patch the wall. I think the second link above includes some patch kits. Go to a good store and ask them ... some of those people really do know what they're talking about.
    As for paint... a bit of a shot in the dark. If you have basically white or offwhite walls, you can probably buy an off the shelf pint of half pint and touch up. Pay attention to sheen.. you don't want to paint, for example, gloss over flat or the filled holes will REALLY stand out.
    If you're really confused, post some pics.
    EDIT: I agree with the others (those posts weren't up when I started), don't do more than is necessary. But.. I've experienced both types of landlords.. some understand normal wear and tear.. some, care more and will get'cha if they can.
  • izafar
    izafar Posts: 819
    edited August 2003
    Thanks guys for the helpfull tips. I will visit Homedepot and check these items out. The idea of squeeze tube sounds good and I will try to get one. My holes are mostly caused by 1/4" thick screws, but there are many as I have tried various scpeaker placements:D
    I do have one big hole which was cuased by runnig a pretty fat cable for dish. That holes runs through the wall and I have to completely fill it.
    -izafar
  • faster100
    faster100 Posts: 6,124
    edited August 2003
    large holes, very large... spray foam then spackle.. otherwise spackle, tube smube... take your finger or putty knife and push it in to the holes. they know you have holes and don't usually want a fit and finish, they just don't want to walk in the door and see what looks like bullet holes all through the house..
    I have moved stuff several times through the 4+ years we have lived here, i go back and spackle after each move/change.. so i don't have to make up for lost time when/if we move..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • TroyD
    TroyD Posts: 13,124
    edited August 2003
    for small holes, and if you are only worried about getting your deposit back, believe it or not, you can use plain white toothpaste as spackle. It doesn't last forever but it works in a pinch to get your deposit back.
    BDT
  • Tour2ma
    Tour2ma Posts: 10,177
    edited August 2003
    Great minds... etc.
    As soon as I read the post I thought "toothpaste"... as a plus it leaves the room minty fresh... :D
    More later,
    Tour...
    Vox Copuli
  • izafar
    izafar Posts: 819
    edited August 2003
    OK, will do a toothpaste test tonight, and if it has better results then I will use it couple of days before moving.
    Thanks.
    -izafar
