Manual for SRS 2's
xsmi
xsmi Posts: 1,801
edited August 2009 in Vintage Speakers
Hey guys,
I've got a little bit of an issue. I am moving into a house in a couple of weeks. The room where I would like to put my SRS's has a wall with a door in the corner which means I will have to place them around 4' from the side walls. I need to know how much space needs to be between them because I am afraid I am not going to have enough space between them. The opposite long wall has windows almost to each corner and I don't REALLY want to cover the windows.
2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Post edited by xsmi on
    nooshinjohn Posts: 25,901
    edited August 2009
    6 feet minimum is my understanding, and My Tl's take up about 1/3 of the windows... My wife wil freak when she sees them for the first time on monday, but I have the room balanced so well that I think she may not even notice.
    F1nut Posts: 51,722
    edited August 2009
    The minimum distance between is 4 feet, 6 to 8 is preferred.
    edited August 2009
    I stand somewhat corrected...
    F1nut Posts: 51,722
    edited August 2009
    Yeah well, 4 feet apart is too close, IMO. :)
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2009
    Four feet is the minimum but then the sweet spot is only 4 to 5' away. Mine are 6' 6 1/2" apart and the sweet spot starts at 6.5' away.
  • xsmi
    xsmi Posts: 1,801
    edited August 2009
    Thanks, 4' is better than the 2 1/2 I have now in my bedroom.
