Bose 901 series III PROBLEM!
c_corie
c_corie Posts: 138
edited December 2009 in 2 Channel Audio
Bought some great shape 901s (for my dad), which have apparently been refoamed.
Hook them up, and anything with bass it buzzy distorted. Yes the EQ is hooked up. It seems like the 1 of the speakers in the back of each of the cabs, is either totally blown, or did not get refoamed right. Any tips on how to tell, they all look the same? Also what are the chances of the same speaker(location) in each cab getting blow? When looking from the back it seems to be the lower most left speaker(s). Any tips?
Post edited by c_corie on
  • zarrdoss
    zarrdoss Posts: 2,562
    edited August 2009
    push it evenly around the cone and see if the vc scrapes, pull the suspect ones and unhook them make sure the wires don't touch and see if it stops If the re-foam was not done right and the vc is not aligned properly it might be the problem.
  • c_corie
    c_corie Posts: 138
    edited August 2009
    I don't see any screws/bolts, just holes? Did the series III have like a locking driver position? There doesn't seem to be anyway to get them out.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited August 2009
    Series III--1976 to 1978, Acoustic Matrix (ported cabinet) Drivers use 3 bolts.
  • zarrdoss
    edited August 2009
    this might help could be glued in or the gasket is acting as glue, might have to pry on it gently
    http://www.audiokarma.org/forums/showthread.php?t=148636
  • c_corie
    c_corie Posts: 138
    edited August 2009
    It appears to be, on closer inspection. one group of the 4 back speakers. Which I hope is a wiring issue, cause how could 4 speakers next to eachother blow, but not that front, or other rear 4? I still can't get them out, maybe the guy glued them in, if he took them out to refoam them:(
  • zingo
    zingo Posts: 11,258
    edited August 2009
    c_corie wrote: »
    It's because they are Bose 901s... :p
    It does sound like a wiring issue if it is a group of drivers, but that still wouldn't account for the buzzing.
  • madmax
    madmax Posts: 12,434
    edited August 2009
    It would take a lot to actually blow any of the speakers. I'm guessing some were not lined up properly by whoever refoamed them. As said above, push them in and see if the voice coil is rubbing. I doubt (but don't know) if they have an electronic network of any kind in side so probably not a wiring problem.
    madmax
    Vinyl, the final frontier...
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2009
    +1 with what everyone has said due to the voice coil rubbing. I mean think about it, if he had to refoam all of those drivers or even half of them there's always a possibility of him making a mistake. That or getting fed up after refoaming the 4th, 6th or even 12th driver and just not paying as close attention as you would after the first one.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • c_corie
    c_corie Posts: 138
    edited August 2009
    So voice coil rub would/is causing what sounds like a badly distored output especially on low freqs? The cabinets are in PERFECT shape for the late 70s, and so is the EQ, but my dad is now considering trading them in, for the Bose new 901 upgrade. They said something like $599, but I still feel terrible that I didn't notice these speakers were making that sound when I went to check them out for him. (Low volume and no EQ hooked up, so I figured that's what they sound like.)
    So should I try to refoam, the ones that need it? It seems like it maybe around 8 of the drivers need it, just by listening to them speaker by speaker. OR should he just trade them up towards brand new ones at what still really is like a $500 discount (after factoring in buying the first set was $250.)?
  • kawizx9r
    edited August 2009
    If its even 8 of them then I can't really say what the culprit here might be. As far as determining whether or not it IS the actual voice coils, you would have to get to each driver and apply pressure evenly on the cone. If you hear a "rubbing" noise of some sort from some but not from others, it means the voice coil is rubbing all because the cone wasnt sitting in its place properly while being refoamed. The surrounds could actually cause a little bit of "pulling" when the drivers show excursion. Test each one out as well to make sure none of them are blown, goodluck to ya anyway though with what you decide.
    Keep in mind, even though one member mentioned they can handle huge amounts of power, if they were damaged I'd have to say possibly because they were being underpowered while being played at high levels.....that is if the issue were something else.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • ctef
    ctef Posts: 3
    Hi, I see it's a little late for ansver of this quest, but if someone need, I can share my experience with BOSE 901-III.
    I own 2 pairs of them,a EQ-IVs,a 550Receiver and Spatial Receiver.;)
    And in the begining met similar problems...
  • bluecomet
    bluecomet Posts: 1,118
    I had those speakers and were not a big fan of them. I sold them and bought more vintage Polk speakers and never looked back. The bose 901 series 6 speakers are better then series 3 and don't have foam to rot. They do not compare to SDA speakers and are pathetic compared to SRS speakers.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • ctef
    ctef Posts: 3
    Yes,I'm very far from the thought, they are the best speakers :-)
    If I compare them, it can be only with full-range speakes.
    Reading contrary opinions about 901s, I became very curious about them. That's why I decided to try 901s at home. In the begining met big difficultys. But in the time overcomed some of them and have some explanations...
    Toolfan66 Posts: 18,189
    ctef wrote: »
    Welcome to club polk! ;)
