Circuit board standoffs for 1.2 TL's
michaeljhsda2
Anybody ever replace the standoffs on the circuit board of the 1.2 TL's? The circuit board has a bit of weight to it and it sure looks like if those standoffs ever come loose or break....well you know the rest
Without a doubt I am going to replace them ASAP. My hope is to find metal standoffs and use plastic washers to prevent a short circuit. Now that I think of it maybe I'll use bolts and nuts with plastic washers.....to be continued.
SDA SRS 2.3TL's
SDA 2B TL's
SDA 2B TL's
Post edited by michaeljhsda2 on
michaeljhsda2 wrote: »Anybody ever replace the standoffs on the circuit board of the 1.2 TL's? The circuit board has a bit of weight to it and it sure looks like if those standoffs ever come loose or break....well you know the rest
You can usually find plastic nuts and bolts in the specialty drawers at Lowe's and Home Depot. Not a huge size selection though. I've also used computer motherboard standoffs (after all, a computer MB is just a big circuit board). Most of the newer boards don't use the plastic ones anymore but you can buy a bag of them at most computer supply stores.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
I'll check out HD and lowe's thanks.SDA SRS 2.3TL's
SDA 2B TL's -
You will laugh at this but I like to shave wine corks to the correct thickness with a very sharp knife and then use hot glue to hold them in place. It really work quite well, you can have any thickness you like and there is no question of short circuits.The world is full of answers, some are right and some are wrong. - Neil Young
