B & K avr 101
polkanddie
Any info would be great, Retail value, wattage, features, opinions.... I couldnt find much online. I have the opportunity to get one cheap. Any help would be greatly appreciated.Thanks
TV- Insignia 46'' LED,1080p,120hz
Monster Power center hts3600 mk2
Onkyo tx sr 503
Rm6600 with 4 sanus stands
SUB(DIY)
Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
extras... RT10's.rti4s.atrium 5's.
"sticking feathers up your butt does not make you a chicken"-Tyler Durden
Onkyo tx sr 503
SUB(DIY)
Post edited by polkanddie on
DId you look here?
http://www.bkcomp.com/support/manuals/past-product-manuals/
I like mine, for what it has. Doesn't do HDMI, but then I just 'direct connect' mine to my tv anyway, sense it has multiple inputs.
105w@8ohm, shitload of connections.
Full set of 5.1 preouts plus a total of 3 other zones full range outputs allows for multiple amp hookups. (why I went for it)
Still figuring out all the features.
If you get it, be sure and "activate" the advanced features options, as it holds a bunch of useful features, and does not appear on the base menu without activations. Can't remember the exact combo, you have to push "sleep, enter & mode" all at the same time..or something like that.....
Don't know if I want to know how much you found it for....LOL:D -
$150, Trying to scrap the cash right now.TV- Insignia 46'' LED,1080p,120hz
Onkyo tx sr 503
SUB(DIY)
"sticking feathers up your butt does not make you a chicken"-Tyler Durden -
Its also about an 1.5 hrs away...TV- Insignia 46'' LED,1080p,120hz
Onkyo tx sr 503
SUB(DIY)
well if its any consolation. that's alittle over half what I paid for mine.
Mine is in pristine condition and came with a Harmony 550 remote.
So if its in good shape, and you like it, why not.
I really like the warmth of the B&K components.
Make sure it has a remote (or a universal) as the replacement ones are $150, and you really need it as I would not want to program it via just the front panel buttons. -
Gotcha, I really appreciate your input, I couldnt get all the money together, so Im seeing if he will let me trade my onkyo tx-sr601, I was wondering though, did this thing really retail for $2500??TV- Insignia 46'' LED,1080p,120hz
Onkyo tx sr 503
SUB(DIY)
polkanddie wrote: »Gotcha, I really appreciate your input, I couldn't get all the money together, so I'm seeing if he will let me trade my onkyo tx-sr601, I was wondering though, did this thing really retail for $2500??
well bear in mind that it is 8yrs old...;) yeah
the 307's, which are only a couple of years newer, are still selling for $500 on Audiogon...
