i think i just figure out a way to power RTIa9s+ x amp with a receiver with no preout
SivaNevets
yes i think this may work
since 95% or more of the time the sound is from my HTPC soundcard (currently Emu 0404 USB and Creative X-Fi Platinum), i think, i can play some tricks with the X-Fi soundcard.
Ill use 3x mini> 2RCA splitters,
1 for front > this goes to the extra amp
1 for center and sub > goes to receiver
1 for rear > goes to receiver
so this is gonna work! yay
although Creative X-Fi doesnt sound good, but Azuntech Prelude is defintely awesome, ill upgrade if im getting the A9s.
and for TV, ill proably use TV S/PDIF > soundcard in > analog out (3x mini>2RCA)
Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
Key Components
•Creative X-Fi CA20K audio processor
•One AKM AK-5394 super high performance 96kHz 24-bit ADC for analog input
•Four AKM AK-4396 96kHz 24-bit advanced multi-bit DAC for analog output
•64Mbytes of memory for audio processing
•High fidelity audio OPAMPs for analog input and output (TI OPA2134)
•Front L/R output OPAMP is replaceable by end-user (National LM4562NA)
•Dual mode S/PDIF receiver and transmitter
Audio Performance (Rated Output @ 5Vrms, Typical Value)
•Signal-to-Noise Ratio (20kHz Low-pass filter, A-Weighted)
•Stereo Output : 120dB (part spec)
•Front and Rear Channels : 120dB (part spec)
•Center : 120dB (part spec)
•Subwoofer and Side Channels : 120dB (part spec)
•Total Harmonic Distortion + Noise at 1kHz (-3dBFS, A-weighted) : 0.001% - part spec
•Frequency Response (+/-0.01dB, 24-bit/44.1kHz input ) : 20khz (part spec)
•Frequency Response (+/-0.01dB, 24-bit/96kHz input ) : 43.5 khz (part spec)
•16-bit to 24-bit recording sampling rates: 32, 44.1, 48 and 96kHz
•Maximum number of 3D Voices: 128
IO Connectors
•One 3.5mm MIC input connector in rear panel
•One 3.5mm line input connector in rear panel
•One 4-pin AUX connector on board
•Four 3.5mm 8 channel line output connectors in rear panel (FL/FR/C/SW/RL/RR/RSL/RSR)
•One S/PDIF combo input connector in rear panel for receiving either coaxial or optical digital
•One S/PDIF combo output connector in rear panel for transmitting either coaxial or optical digital
•One 10-1pin front panel connector on board for MIC input and headphone: more
•One 40-pin digital extension header on board to support AD-Link and other digital functionality
Swappable OPAMPs
•All Auzen soundcards support swappable OPAMP sockets for OPAMP upgrades.
S/W and drivers
•Creative X-Fi DriverFront: Martinlogan ESL
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
