exact measurement for CS2
d0minicano
Hey everyone I currently have r50's upfront powered by my Onkyo 607. I been piecing my system and now am looking for a center channel. The one I am looking at is the CS2 model. Now I have a perfect spot on my tv stand but I needed the exact measurement which polk does not provide. Since this speaker has an angle on the back i needed to know how deep it is at the top before the angle and also how deep it is 1 1/4 inch into the angle. on my tv stand there is like a shelf but about 4 3/4 inches in there is a bar that is 1 1/4 tall on top so I was trying to see if it would fit in there or if it would be sticking out. If it does not fit I can always put it on top. Also if you guys recomment anything different with that would compliment the r50's would be great, also for the rears I have a pair of m20, thanks for you help!
Post edited by d0minicano on
7-3/4" H x 21-1/4" W x 11-1/8" D is the exact measurement of the CS2 taken by Polks website, respectively. Welcome to Club Polk!Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
that I know but I am looking for the measurement where the angle starts
The height is the height of the speaker at its highest point, so from the front of the speaker as youre looking at it. The angle isnt too steep, my cs350's height in front is 6 1/2" and in the rear the height is 4"....at a depth of 10" (excluding grill)Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
yeah the height is not the problem for the first 4.74 inch but after that I have a bar that is 1.25 inch hanging after it. Thanks for you help but I wanted to know from someone who actually owns this speaker, I could go to fry's to measure it but its 30 miles away so I thought I try here first with someone who actually owns it.
Alot of people own it here and are quite happy with it so I bet someone can chime in. Otherwise maybe googling it might come up with the results youre looking for? Anyway goodluck to ya and hope it works out.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
d0minicano wrote: »that I know but I am looking for the measurement where the angle starts
The angle starts at 5" (not including the grill) -
Thank you very much it does help I would be pointing regular pointing straight the stand I have it the following http://www.amazon.com/BellO-AVSC-9870-Stand-65-inch-Displays/dp/B001RIYORO/ref=sr_1_3?ie=UTF8&qid=1248665418&sr=8-3
it is going to be sticking out atleast an 1 1/4 because of the grill. i will be able to fit in in the bottom part and put my xbox, ps3 and wii on the shelf instead since it is 40" wide and point it upward with the notch since it will be closer to the floor. Thanks for you help
