exact measurement for CS2
d0minicano
d0minicano Posts: 4
edited July 2009 in Speakers
Hey everyone I currently have r50's upfront powered by my Onkyo 607. I been piecing my system and now am looking for a center channel. The one I am looking at is the CS2 model. Now I have a perfect spot on my tv stand but I needed the exact measurement which polk does not provide. Since this speaker has an angle on the back i needed to know how deep it is at the top before the angle and also how deep it is 1 1/4 inch into the angle. on my tv stand there is like a shelf but about 4 3/4 inches in there is a bar that is 1 1/4 tall on top so I was trying to see if it would fit in there or if it would be sticking out. If it does not fit I can always put it on top. Also if you guys recomment anything different with that would compliment the r50's would be great, also for the rears I have a pair of m20, thanks for you help!
Post edited by d0minicano on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2009
    7-3/4" H x 21-1/4" W x 11-1/8" D is the exact measurement of the CS2 taken by Polks website, respectively. Welcome to Club Polk!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • d0minicano
    d0minicano Posts: 4
    edited July 2009
    that I know but I am looking for the measurement where the angle starts
  • kawizx9r
    edited July 2009
    The height is the height of the speaker at its highest point, so from the front of the speaker as youre looking at it. The angle isnt too steep, my cs350's height in front is 6 1/2" and in the rear the height is 4"....at a depth of 10" (excluding grill)
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • d0minicano
    d0minicano Posts: 4
    edited July 2009
    yeah the height is not the problem for the first 4.74 inch but after that I have a bar that is 1.25 inch hanging after it. Thanks for you help but I wanted to know from someone who actually owns this speaker, I could go to fry's to measure it but its 30 miles away so I thought I try here first with someone who actually owns it.
  • kawizx9r
    edited July 2009
    Alot of people own it here and are quite happy with it so I bet someone can chime in. Otherwise maybe googling it might come up with the results youre looking for? Anyway goodluck to ya and hope it works out.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Osarion
    Osarion Posts: 188
    edited July 2009
    d0minicano wrote: »
    The angle starts at 5" (not including the grill)
  • d0minicano
    d0minicano Posts: 4
    edited July 2009
    Thank you very much it does help I would be pointing regular pointing straight the stand I have it the following http://www.amazon.com/BellO-AVSC-9870-Stand-65-inch-Displays/dp/B001RIYORO/ref=sr_1_3?ie=UTF8&qid=1248665418&sr=8-3
    it is going to be sticking out atleast an 1 1/4 because of the grill. i will be able to fit in in the bottom part and put my xbox, ps3 and wii on the shelf instead since it is 40" wide and point it upward with the notch since it will be closer to the floor. Thanks for you help
