USB to HDMI converter box now available
danger boy
THis may be a solution to some problems some people are having by using a PC in their home theaters.
http://www.costco.com/Browse/Product.aspx?Prodid=11477430&cm_mmc=BCEmail_431-_-FOCUS-_-18-_-AtlonaUSBtoHDMI
http://www.costco.com/Browse/PopupViewer.aspx?prodid=11477430&whse=BC&cat=52001&lang=en-US
Atlona Technologies presents the all new USB to HDMI adaptor, the AT-HDPiX. This new solution is designed to add a HDMI port to any computer (Mac or PC) and has limitless applications in both consumer and commercial environments. From digital signage to home theater, the all new HDPiX provides a simple solution for viewing content from a computer on any HDTV making it the perfect device for any consumer or commercial application. Set up is as simple as plug and play; convenient for any user, no matter the level of technical knowledge. Connect up to 6 x AT-HDPiX to a PC and up to 4 x AT-HDPiX to a Mac.
Package Includes:
ADDED VALUE: 6' HDMI Cable
1 x AT-HDPiX (USB to HDMI Converter)
1 x Mini Audio Cable
1 x USB Cable (5-pin mini to USB-A)
Features:
HD TV or Projector Compatible
Resolutions supported up to UXGA 1600x1200 or 720p
Up to 6 x AT-HDPiX can be used w/1 PC and up to 4 x AT-HDPiX w/1 Mac
32 bit True color depth of high quality images
Capable of Mirroring or Extending Display
Standard and wide-screen aspect ratios (4:3 or 16:9)
Compatible with all CRT and Flat Panel monitors w/HDMI port
Auto display ID using VESA compliant protocols
Audio input through 3.5mm (1/8-inch) stereo jack
Audio Embedded into HDMI
Quick and easy installation
Supports Windows 2000, XP and Vista, Mac OS X 10.4.1 and higher
USB Powered (no external power needed)
Includes software, USB cable and audio cable
Minimum PC Requirements:
CD-ROM Drive
Windows 2000 SP4
Windows XP SP2
Windows Vista SP1 (32-bit and 64-bit editions)
One USB 2.0 port
512mb of Ram
Pentium 4
30 megabytes (MB) of free disk space
Computer screen for use with the HDPiX device
Minimum Mac Requirements:
CD-ROM Drive
OS X 10.4.1 or higher
One USB 2.0 port
17 megabytes (MB) of free disk space
Technical Specifications:
Compatible with Windows 2000, XP and Vista
Compatible with Mac OS 10.4.1 or higher
USB connector: mini-USB female
HDMI connector: Standard HDMI 19-pin female
Dimensions: 3.2" W x 0.8" H x 2.2" D
Weight: 1 lb.
[Model AT-HDPiX]
Package Includes:
Features:
CD-ROM Drive
Windows 2000 SP4
Windows XP SP2
One USB 2.0 port
512mb of Ram
Pentium 4
CD-ROM Drive
One USB 2.0 port
Weight: 1 lb.
[Model AT-HDPiX]
PolkFest 2012, who's going>?
Post edited by danger boy on
Man, if people just had a little more "knowledge" about what they're trying to accomplish such devices like these wouldn't be needed. Just something someone came up with to get some more $ in his/her own pocket, good idea imo.
Wonder how much would be affected regarding transfer rate speeds......I mean we're talking audio/video in hi-def over usb?Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
My custom HTPC has an hdmi out, and it's a relatively low end board, plus it' over a year old? I'd probably just use my optic/ DVI out instead of this route.
Hell, I just bought 2 hdmi cables so I can use my brdp. Wouldn't have if I didn't NEED to!
I imagine that the brand HTPC's will have hdmi out, if not now, then in the very near future?I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Using this at it's max resolution would kill your entire USB bus in terms of saturation.
Your CPU% utilization would be extremely high as well. A low end video card would be a better solution.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I'm not sure this will work very well, isn't USB relatively limited with regards to data transfer speed?polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
According to the video
- an 1/8" headphone jack/cable supplies the audio - so the audio signal is only in stereo?
- the USB only needs to supply Video only, and it is only 720p?
It should work adequately.........
I've run lots of movies off a USB external HD at this resolution with stereo sound and it works fine - never stutters........
