Will this stand work for my RTI6?
SivaNevets
SivaNevets Posts: 303
edited September 2009 in Basic Hookup/Wiring Questions
For HD front speakers, seating level (sofa)
Supra Adjustable Monitor Stand
Height: 690-1300mm
Plate Size: 230x230mm
Base: 450x450x450mm
Shipping Weight: 10lbs
the plate size is a little smaller than RTI6 footprint.
i finally find some thing affordable.
Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU
Post edited by SivaNevets on
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    looks good...
    how much do they sell for with shipping.
  • SivaNevets
    edited July 2009
    forgot to put the link
    http://www.stevesmusic.com/index.php?main_page=product_info&cPath=8_195&products_id=3364
    $35 CAD each, this store is right beside me.
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
  • Willow
    Willow Posts: 11,227
    edited July 2009
    do you have pets or kids around? as I don't see a great method to keep the speakers on the stands in case of bumping into.
  • superjunior
    superjunior Posts: 1,632
    edited July 2009
    I have almost those exact stands, the base is shaped a bit different but the dimmensions are the same. I tried using velcro strips to secure the speakers to the stands - cheap surrounds a bit smaller than the rti6's. Those speekers have hit the ground more times than I care to count, and I don't have kids. When I get new surrounds I'll be giving those stands away...
    jr
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • SivaNevets
    edited July 2009
    no kids, 1 gaf, 1 bunny. i seriously dont have a lot choice..
    another one im looking at is this
    http://www.long-mcquade.com/?page=products&ProductsID=1332
    sure more secure but the plate seem too small to me..
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
  • superjunior
    edited July 2009
    I don't have a lot of choices with my surrounds either. stands for now. other than bolting the speakers to the stands, I don't know of a good way to secure them. I'm starting to consider 4 floorstanders for my surrounds. a5's? :D if you gotta use stands, get some sturdy ones with a big speaker base that aren't tippy. btw siva, what's a gaf?
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • jimmydep
    jimmydep Posts: 1,305
    edited July 2009
    You could try using a heavy duty double sided foam tape to secure the speakers to the stand. I can lift my stands by the speaker, so there's no chance of them falling off accidentally.
    Jimmy
  • SivaNevets
    edited July 2009
    will foam tape damage the speaker? which one u guys think is betteR?
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
  • John K.
    John K. Posts: 822
    edited July 2009
    Siva, both of the stands that you've linked seem a bit too tall to put the RTi6 tweeters near ear level. For a shorter, sturdier(and less expensive)stand, consider this one .
  • SivaNevets
    edited July 2009
    thx, Plate Size: 152x100mm
    is this too small?
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
  • SivaNevets
    edited August 2009
    just bought these (the one in the images). will put them up after moving @ sep 1 and will share some of my thoughts
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
  • alibaba128
    alibaba128 Posts: 15
    So, have you had the time to install them?
    HT system (work in progress):
    -RTi6 fronts, CSi5 center (to buy), RTi4 rears
    -PSW505 sub
    -Emotiva UMC-1 pre/pro (waiting for retail release)
    -Emotiva XPA-5 (to buy)
    -Raxxess ERSS-36 stands
