Need a good receiver for LSi7
jolax73
jolax73 Posts: 225
edited July 2009 in Speakers
Polk Audio mania!
I have a pair of Lsi7 and wanting to use it for HT and music. I am looking for the best bang for the buck for the receiver but not really sure what to get since I have been reading in the forum that this speaker is power hungry. I am thinking of all in one receiver that has 5 channels and HDMI input but could not find any in the forum. I was inclined on the NAD C720BEE but this looks only a 2 channel amplifier and not a receiver. Any recommendation for a under $500 receiver for this lovely speakers? Also is DSW Pro 500 sub compliment this or should a Yamaha YSTSW216BL will do justice to this speakers?
Again, I am a new bee in home speaker system and what kind of cable is highly recommended for these Lsi7. I haven't got the rear speakers yet, any recommendation for a good price and sound? Also for the center channel, still looking.
Thanks in advance for the advice and input folks!!
Post edited by jolax73 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2009
    xcapri79 wrote: »
    You are on the right track on using NAD. You might find something like a NAD - T-755 for close to what you ewant to pay. The LSi7's are not a demanding as the rest of the LSi series in that it doesn't go below 4 ohms as say the LSi9 does, however you need a good receiver with a 4 ohm rating such as the NAD or use a separate amp with a receiver with pre-outs. I would say you will need to check the used market to meet your price point.
    +1
    Find yourself a good pre amp/receiver and utilize it as your pro. Many good AVR's can be had for around what youre looking to spend, but you will have to cough up some more coin for a proper amp to power the LSi's. You'll find alot of owners will chime in and recommend you run these off a seperate amp, even if it's just a 2 channel amp as several people here run more than 1 seperate amp for their HT setup.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • jolax73
    jolax73 Posts: 225
    edited July 2009
    Yeah, I was reading more forums regarding the Lsi7 and I kind of hooked to the Emotiva XPA-5. So this seems like a separate amplifier and no receiver. So if I were to use this, I would need a receiver still to plug all my HDMI inputs, right?
    How is the XPA-5 paired to Lsi7 compared to the NAD T755??
  • kawizx9r
    edited July 2009
    A receiver with pre amp outputs, make sure it has pre outs as few people have made this mistake in the past *raises hand* not like it matters in my case unless I want to use my SDA's as part of my HT, thats for another thread though :eek:
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • jolax73
    jolax73 Posts: 225
    edited July 2009
    So does any kind of receiver matter or do I still get a good one. I mean if I use a so so receiver, but good amplifier, will it make the sound different? I am saying is will the receiver just work as a bypass?
    Please help me understand....thanks!
  • kawizx9r
    edited July 2009
    Good receiver should still be in the works, not all DACs are the same. Some will seem "warm" others "bright" and so on. Personally I like my Denon as it sounds a bit more natural than my older Pioneer I replaced, but I've heard a few HK's I liked. Never owned/heard Onkyo so I can't say anything regarding them but those who own them will give you their .02
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Barefoot
    Barefoot Posts: 149
    edited July 2009
    an old nad receiver i had before the m3 upgrade drove my 9's w/o fuss. Aren't the 7's 6ohm speakers? Shouldn't be a problem. Personally I think the whole amp/pre argument is somewhat overblown. jmo.
  • jolax73
    jolax73 Posts: 225
    edited July 2009
    Look at T755 specs and does not seem to have the hdmi support. IS that correct? Also polk audio manias, what is the best bang for the buck receiver/amplifier for the lsi7 that can give warm sound. Yes, I like warm sound, not the bright kind like Sony or Pioneer speakers.
    Again my option are either go with NAD T755 receiver, or get the Emotiva XPA-5 (seems to have very good review for the price; but not really sure if this is a good match with the Lsi7) or the Harman Kardon....but my problem I am thinkng of creating a 5.1 setup or maybe even just 4 channel without a center speaker.
    Please help me with choosing the right amplifier/speaker and what is the good wire speaker for this set?
    Thanks again folks for the reply....!!
  • jolax73
    jolax73 Posts: 225
    edited July 2009
    BTW, the T755 also does not support HDMI audio. Is this a big deal? Does this has pre-outs? Anyone that used T755 to power their LSi7, please let me know your experience.
    Please share your experience running the Lsi7 with other amp or receiver.
  • cfrizz
    cfrizz Posts: 13,415
    edited July 2009
    Just like the rest of the LSI's the 7's enjoy & benefit greatly from power. My Brother has them. He originally ran them off of a Rotel 50wpc amp prepro combo. While they did sound good, after a 2 hr movie, you could fry an egg on top of the amp!
    He now runs them with a Denon receiver & a 205wpc Parasound amp. They sound even better & the amp stays nice & cool.
    He has to crank the Denon up quite a bit to get the volume he wants, but with the amp in place, he doesn't have to worry about it going into protect mode.
    This is what proved to me how much power it takes to drive the LSI series. I figured he would have plenty volume at -30 which was just fine with my RTA-8T's, but it was nothing on the LSI's.
    One other note is that you WILL need a sub to fill in the bottom end. When watching a movie or listening to music the 7's really struggled to play everything. By adding a sub the 7's will be able to excel at what they do best, rather than sounding kind of muddy trying to play the low bass.
    Welcome to Club Polk!
  • Shicks18
    Shicks18 Posts: 397
    edited July 2009
    imho, you've stepped into a potentially expensive hobby, especially with the purchase of LSi7's. With that kind of purchase, you raised the standard/expectations on the remaining equipment. I don't know what kind of plans you have in store on the future, but if it is to purchase more speakers, assuming they are LSi speakers, then you will need a powerful multi channel amp.
    With that said, the previously mentioned XPA-5 will be wonderful. To maximize sound quality while still keeping your budget in mind, you need to buy the amp used, as well as purchase a used preamp/processor. You can try another Emotiva product, the LMC-1, to suit your needs. When it is all said and done you've spent around $800 or so on the proper processing/amplification.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • jolax73
    jolax73 Posts: 225
    edited July 2009
    Hmm....so now I am a bit confused as to go with the NAD T755 receiver or the Emotiva XPA-5 or also the need to get the pre amplifier.....
    Is it really necessary to get the pre amp if I were to use the EPA-5??
  • jolax73
    jolax73 Posts: 225
    edited July 2009
    cfrizz wrote: »
    CFRIZZ so what is the consensus, what is your recommendation to run my Lsi7? Should I get a receiver and separate amp? If so, what brand do you recommend for the amp and the receiver?
  • cfrizz
    edited July 2009
    Jolax you have to decide for yourself if you want to buy a receiver for all the latest bells & whistles with preouts & a separate amp. or go straight for a prepro & amp realizing in most cases the prepro won't have all the latest & greatest.
    I have had both types of sytstem & prefer the prepro/amp combo.
    Good amps are Parasound, Outlaw Rotel, Emotiva, Nad, Adcom, Sunfire, B & K, etc. www.Audiogon.com is your friend.
  • jolax73
    jolax73 Posts: 225
    edited July 2009
    Polk Guru, I have decided to get a separate amp and a receiver. For under $700 amp, what is the recommended top 3 5-channel amplifier? I was looking at that price range, so far is Emotiva XPA-5. IS this a good pair with the Lsi, meaning it can bring out the warmth and the character of this speaker?
    Let me know your thought on this. thanks!
  • cfrizz
    edited July 2009
    The XPA will do just great with the LSI's. And right now it is the best bang for the buck amp to get brand new.
    I saw where you are looking for a Rotel 1075, but if you plan on adding more LSI's, that Rotel really won't cut it.
    We had a guy a few years back who went with one for his system. I was the lone one that said hold out for more power. Needless to say he was back on here complaining that his amp went into protect mode & got really hot.
    It's better to have it & not need it rather than need it & not have it.
    Good luck in your search for an amp.
  • jimmydep
    jimmydep Posts: 1,305
    edited July 2009
    jolax73 wrote: »
    What cfrizz said +
    The XPA-5 is a great compliment to the LSI speakers......the XPA-5 is a very dynamic and powerfull amp, the LSI's being very laid back will jump to life with the Emotiva.
    I actually like my XPA-5 better than my Sunfire Cinema Grand with the LSI's.
    Jimmy
  • jolax73
    jolax73 Posts: 225
    edited July 2009
    So Jimmydep...what other option aside from Emotiva XPA-5 since I got a yes from you.. Any other similar quality and price?? Just for an option here.
  • jimmydep
    edited July 2009
    jolax73 wrote: »
    If you want a very warm sounding amp the Sunfire Cinema Grand 200x5 would be an excellent choice and you can select between voltage and current source outputs, the current source is supposed to mimic the properties of a tube amp, I found that output to be luke warm and it did nothing for the LSI's. A used Sunfire amp can be found in the $800+ range.
    Here's one on e-bay now auction closing in about 2 hours http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=320397186649
    I can only personally speak for the two amps that I own, many here like the Rotel, Parasound and Adcom amps.
    Whichever you choose for your LSI's I'd make sure you have at least 300wpc@4ohm, just in case you want to bump up to the larger LSI's or any low impedance speaker in the future.
    Isn't this fun....
    Jimmy
  • shack
    shack Posts: 11,154
    edited July 2009
    Not an absolute.
    I would forego the HDMI inputs and go with the NAD T755 in a heartbeat. HDMI for audio is is not necessary and the HDMI video can be run straight from the DVD player to the monitor. New at $799 or refurb at $699...either is a killer deal. I pesonally would not buy and Emovtiva product over a NAD...but that is my preference. Also...don't be fooled by the 80wpc...it is deceptively CONSERATIVE. The T755 will drive the LSi7s effortlessly...to levels louder than one should listen to. The NAD recievers are also considered to be exception for music reproduction...not just HT.
  • Face
    Face Posts: 14,340
    edited July 2009
    LSi7's are easy to drive in comparison with the rest of the LSi series. A good integrated or receiver(such as HK, etc...) should be able to drive them without a problem. LSi9's and LSiC's, that's a different story, I would definitely recommend an amp.
  • shack
    shack Posts: 11,154
    edited July 2009
    Face wrote: »
    Again, you have to be careful of generalizations. One of the best 2 channel rigs I ever heard was a pair of LSi9s running off a NAD C320BEE integrated rated at 50wpc in a medium sized room (no sub). IIRC the source was a modded Sony C222ES CDP. Talk about synergy...It was a sweet sounding setup that I would be proud to own.
  • jolax73
    jolax73 Posts: 225
    edited July 2009
    Polk Guru,
    Thanks for the input once again. I am prolly convince that you definitely know what u r talking about here. So I might stick to the NAD T755...but what about that Sunfire Grand Cinema that was mentioned earlier by one of the responder. Which would you recommend?
  • Face
    Face Posts: 14,340
    edited July 2009
    The Grand Cinema is a good amp if you plan on adding a LSiC and surrounds.
    IMO, it would be silly to purchase a new processor/receiver that doesn't have HDMI, you'll be missing out on the new audio formats and will have a lot less cables to deal with.
  • jolax73
    jolax73 Posts: 225
    edited July 2009
    Face, that's is what I plan to do, to have a center speaker (Lsic) and a surround. What do u recommend for the surround to compliment my LSi7. I don't need expensive surround but just something not big and nice sounding for the surroung, any suggestion?
    And for this kind of setup what do you recommend since you mention about not recommending buying the NAD which do not support the HDMI audio. Let me know your inputs. Thanks!
  • cfrizz
    edited July 2009
    The Sunfire is also a good option. If you check my signature, you will see I have one myself. Either a Sunfire or the Emotiva will get the job done, now & in the future through all other upgrade to your system.
    The Sunfire can be gotten on Audiogon or Ebay. Personally I trust Audiogon more.
  • cfrizz
    edited July 2009
    So long as he is using the amp I hardly think he will be losing performance or money. There is also the fact that he intends to add more LSI speakers which will be a further drain on any receiver he gets regardless of the quality of the product.
    Either way you slice it, it is going to cost quite a bit of money to do this properly. When all is said & done I'd rather overspend once & be all set for years to come, rather than take a cheaper short cut & come up wanting.
    Jolax, now has both sides of the argument, lets just let him decide which direction he wants to go in.
  • jolax73
    jolax73 Posts: 225
    edited July 2009
    cfrizz wrote: »
    Cfrizz,
    What is a prepro by the way?? Sorry I am new to home audio...so some of the terms are not familiar yet.
  • apphd
    apphd Posts: 1,514
    edited July 2009
    jolax73 wrote: »
    Cfrizz,
    jolax you will see this term often. It is a preamp/processor, basically the controller/heart of your system. Basically an AVR incorporates the prepro and amp into one chassis. Separates as the name implies puts the amp in one chassis and the prepro into another.
    There are benefits and drawbacks to both approaches.
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2009
    SC-05 with an external power amp.
  • cfrizz
    edited July 2009
    Apphd nailed it Jolax. A prepro is the brains & the amp is the muscle. All decoding of information from all sources (dvd player, cd, etc.) is done through a prepro.
    jolax73 wrote: »
    Cfrizz,
