Help me hang my speakers!
CuE0083
If I want to wall mount my Rti4's and FXi4's can I just hang them like a picture using the keyhole slot? I was planning to just use a hammer and nails to accomplish the task...
Post edited by CuE0083 on
DOn't use nails, If you can find a stud in the wall that would be best, but these speakers only weigh about 15lbs so threaded drywall anchors with screws using the keyhole slots would work well for you.
Here is a link that shows you some of the different anchors available
http://www.renovation-headquarters.com/drywall-anchors.htm
JImmy -
JImmy
Good words. Just to add - you can find those anchors (or good quality screws) in any hardware store such as Home Depot.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
just hung my f/x500i's, this is what I used:
http://http://www.acehardwaresuperstore.com/tapnlock-anchors--screws-anchor-hangs-up-to-50-lbs-p-84001.html?ref=42Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Will I need a power drill?DOn't use nails, If you can find a stud in the wall that would be best, but these speakers only weigh about 15lbs so threaded drywall anchors with screws using the keyhole slots would work well for you.
JImmy -
It would definitely make it much easier. Without one you'll make a mess.Main Surround -
check out crutchfield
they have a range of wall mount speaker brackets that are reasonable in price.
some are adjustable
http://www.crutchfield.com/g_15830/Speaker-Wall-Mounts.html?showAll=Y&tp=586 -
Definitely much better solution! Just make sure you keep those nails away from those walls and speakerscheck out crutchfield
some are adjustable
Cheers!
TKDARE TO SOAR:
http://www.jr.com/btech/pe/BTH_BT77/
Lot of polkies have used the B-Tech BT77. jr.com has it on sale.
RTi4s using BT-77 mounts:
http://erikt.cts.com/Pictures/hometheater/home-theater-2.JPG
Works perfectly!
If you use the threaded drywall anchors you won't need to use a drill as they are self tapping and very easy to use.
As far as some of the other suggestions to use speaker mounts...those would be the preferred method if you need the ability to direct the speaker, if you just want the speaker to face straight out from the wall then save your money and just use the keyhole mount on the speaker.
Jimmy -
FYI......when using the keyhole mounts on the speaker make sure you get #10 pan head screws, and leave them approx.1/8" to 1/4" from the wall.....#12 screws are too big to fit into the hole and #8 screws are too small...........just trying to save you an extra trip to the hardware store.
Jimmy -
Well my new plan is to use speaker stands for the fronts and mount the surrounds on the wall. I figure that I won't really need to adjust the position of the surrounds when they are keyhole mounted to the wall.
Thanks for the help! -
