Will my AVR suffer damage?
kawizx9r
kawizx9r Posts: 5,150
This may actually be a dumb question, but I would just feel better if I heard it come from someone else. I'm using a Denon 684/1604 AVR to power my HT, I also have a stand alone 2 channel setup with SDA's hooked up to it. I'm really liking the sound of my SDA's and would like to use them as my front channel setup of my HT, thing is I don't have pre amp outputs on my AVR. I have my blu ray player hooked up to my AVR via optical digital out, while at the same time connected to the preamp of my 2 channel setup via rca IC's. Will any damage be caused to my AVR if I run it powering only my center+surrounds but no front channel load? I know some AVR's don't suffer any damage but those have pre amp outs and mine doesn't, was wondering if it'd act any differently, thanks.
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104
heiney9 wrote: »
Any clue how to use the internet? Found it in about 10 sec.
Post edited by kawizx9r on
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited July 2009
    No damage at all. But I am wondering how you would integrate the two systems together for HT.
    edited July 2009
    That's an interesting question. Firstly, the R/L outputs of the pre-amp are receiving a down-mixed 5.1 surround soundtrack...so that will interfere with the true discrete info being passed to the rest of the channels in 5.1 or 7.1...?
    Secondly I'm not even sure the Denon will ALLOW you to run it if there are no fronts hooked to it? I could be wrong here...but I don't think so?
    cnh
  • kawizx9r
    edited July 2009
    It was worth a shot considering:
    1 My living room is small and having SDA's with a pair of tower RT1000P's just takes so much space
    2 I've seen more and more people utilize their SDA's as their front channel setup and seem pleased with the result
    3 Among those people that use their SDAs as fronts, they all seem to have CS400's or CS350's as their center channel (one very common factor I've noticed) and I myself have a CS350.
    4 Having such "large" speakers as fronts, would only be ideal if I used my towers as rears for full dynamic sound from all angles.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    edited July 2009
    cnh wrote: »
    cnh
    The Denon runs fine actually, well it has for the first hour I've been watching Transformers on blu ray, and doesn't seem to be getting any hotter than it usually does or anything. I was just worried over the long run
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    edited July 2009
    That's fine, you definitely won't hurt anything...but you have A FULL 2 channel soundtrack on your SDAs and 3.1 or 5.1 on the rest of your system minus the discrete L/R info?
    That should sound a bit 'off'.
    cnh
  • obieone
    obieone Posts: 5,077
    edited July 2009
    I can't imagine that it would? What are you going to do with the RT1000's, set up a second 2 ch. rig?
  • kawizx9r
    edited July 2009
    Yea, I'll just hold it off until I can get a receiver with pre outs and just use that as my pre/pro and hook up my tube to that for my SDA's? So far it does sound a little off, but it just may be the fact that my AVR is doing 3.1 and my SDA's full 2 chan like you described.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • kawizx9r
    edited July 2009
    obieone wrote: »
    Was going to use the RT1000's as rear surrounds
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    edited July 2009
    Here's what you should do! If your Blu-ray has 7.1 RCA outs or 5.1....and the Denon 7.1 ins or 5.1. Connect the Blu-ray using all RCAs and pass the L/R to your pre-amp. That way the Blu-ray will decode everything and separate it to the Denon and to the Pre in the appropriate manner! You should connect that way in any case because that Denon does not have decoding for TRU-HD formats?
    Problem solved?
    cnh
  • kawizx9r
    edited July 2009
    It's been awhile since I've actually looked behind my blu ray player, that thought did occur while looking at my sacd/dvd-a player because it has analog outputs for each channel, don't think my blu ray player does though gimme a few minutes.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • jimmydep
    jimmydep Posts: 1,305
    edited July 2009
    cnh, good idea....best of both worlds.
    Jimmy
  • kawizx9r
    edited July 2009
    Nope, it doesn't unfortunately. I'll just wait to pick up an avr later in the future with pre outs. That'll have to wait though since I'm not looking to rush anything anytime soon, my RT1000's are awesome front channel speakers imo
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • thuffman03
    thuffman03 Posts: 1,325
    edited July 2009
    I don't think it will do damage to the AVR but you could do damage to the speakers if you get to high volumes and over drive the AVR and it starts clipping.
    I would upgrade and make sure you have a good amp on the SDA's. For now just keep it at lower volume till you can get a bigger amp on them.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • kawizx9r
    edited July 2009
    thuffman03 wrote: »
    I don't get it?...I do have a good amp on my SDA's, running a Moscode 300 just for them, and my HT setup is run off a Denon AVR. I was mainly concerned about my AVR running only my center+surrounds and if any damage would be caused because I wouldn't have front L/R channel speakers hooked up to it.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited July 2009
    kawizx9r wrote: »
    You do not have to worry about damaging your AVR as previously mentionned. In fact, you are freeying some extra power for the speakers that are hooked-up to the AVR.
    AVRs and Amps use reference voltage which remains constant, not having a speaker hooked-up to some of the channel simply keeps this path open (just like a switch would do when the path is opened) not allowing the current to flow and that unsused current can then be used elsewhere.
    As far as your SDAs, as long as that external Amp has enough power to drive them, you will not have any problems. The only reason to have problem would be if the Amp has a much lower power rating or higher impedance value than the SDAs then and only then you could have issues (if lower power from the Amp, could cause clipping. If higher impedence at the amp, could cause the Amp to overheat) but otherwise you are fine.
    Driving an Amp is a combination of the voltage reference and the current (ExI = P). The current is flowing as per load demand, if load isn't present then there is simply no flow and will not damage the AVR as this is the way it is designed to work.
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • Serendipity
    Serendipity Posts: 6,975
    edited July 2009
    You should be fine.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • kawizx9r
    edited July 2009
    TECHNOKID wrote: »
    Cheers!
    TK
    Thanks :D as far as the tube goes thats alright. It can handle anything from 8ohm (150wpc) down to 4ohm(300wpc) and my SDA's are 6ohm. I even hear about people running sda's on a tube at 20wpc :confused:
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • TECHNOKID
    edited July 2009
    kawizx9r wrote: »
    Why not, a larger amp can easily drive the 20wpc without any issues, it is a simple matter of not cranking too high (you would hear the distortion anyway).
    DARE TO SOAR:
