Quick answer onkyo 875
Nacken23
Nacken23 Posts: 100
edited July 2009 in Electronics
does onkyo 875 have pre outs for connecting an amp:confused:
Post edited by Nacken23 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2009
    Zone 2,3 pre outs on the far right of the AVR above where you connect your surround speakers, never owned an Onkyo though so not sure if those actually work that way or just control another source thats hooked up to the AVR.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Nacken23
    Nacken23 Posts: 100
    edited July 2009
    thank you so it does is it worth getting an refurbished 875 over a new onkyo 806? Your advice is much appriciated:)
  • kawizx9r
    edited July 2009
    I hope Onkyo owners chime in here, but imo if its a relatively expensive unit I always look to purchase, I always go with used due to price differences. It all depends what youre looking for in an AVR, and youre on the ball with looking for something that has PRE outs for upgrades down the road. By the way what speakers are you going to run for this AVR?
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Nacken23
    Nacken23 Posts: 100
    edited July 2009
    I will be using the avr to run my old crappy panasonic speakers for now and will use the pre outs to connect my new rotel amp 500watts @4ohms to power my new lsi15s
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited July 2009
    If using an outboard amp, the main advantage of the 875 would be the Reon video processor. But the Reon in the 875/885/905 puts out the incorrect color space, and stretches any input, including 4/3, to full screen, making everything stretcho-vision. Pretty much worthless. The 875/885/905 are also known for lip-sync issues, the audio is behind the video (97ms delay) there is no way to adjust it out.
    This was all fixed in the xx6 versions with new firmware (same hardware), but was never corrected in the xx5 series. Onkyo supports suggestion was to buy the new model. :mad: For that reason alone, I will never purchase an Onkyo product again. I sold my PR-SC885 after waiting 11 months for firmware to fix these issues, but once the new models came out, all support ended.
  • Nacken23
    Nacken23 Posts: 100
    edited July 2009
    Thanks for your advice not sure what to do now anyone else have anything to say about onkyo 806 or 875?
  • bklynNupe
    bklynNupe Posts: 728
    edited July 2009
    Nacken23 wrote: »
    I own the Onkyo 806 - 7.1 with emotiva 2 and 3 channel amps. I do not have any clearance behind my seating area so two left over rear channels simply go to waste.
    I have HD directv and a upscaling dvd player so the upscaling on the onkyo also goes to waste. I like the functionality and the Audyssey set up. In retrospect, I wonder if my money might have been better spent on something else given I don’t use it for amplification? :o
    I also run my directv and digital music through a Music Hall DAC before it gets to the Onkyo. I’m pretty sure everything above the Onkyo 606 has pre-outs.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
  • Nacken23
    Nacken23 Posts: 100
    edited July 2009
    Cheers for your help and advice:)
    edited July 2009
    If you don't BOTHER with UPCONVERSION and just pass through the 875 is the superior pre/pro for sound/music. It has Burr Brown 1792 DACs all around and also features Onkyos VLSC (sound shaping algorithms for smoothing out the wave curves of digital sound formats).
    Both the 806 and 875 have 8 pre-outs. No problem there. The 875 is fairly musical due to the above features, etc.
    good luck...(William above...yeah, Onkyo CS pretty much suxx...for support you have to HOUND them...been there done that. But they still offer one of the best feature sets to price ratio on the market, unfortunately?).
    cnh
  • Nacken23
    Nacken23 Posts: 100
    edited July 2009
    WilliamM2 wrote: »
    You say these issues were fixed in the xx6 versions so if I buy an onkyo 876 would I not have any of these issues plus I would get more features with the onkyo 876?
    Please comment guys ur advice is much appricated:)
  • WilliamM2
    edited July 2009
    The Reon issues are reportedly all fixed in the xx6 series. You can also make per input video adjustments on the 876, the 875 settings were all global. You will also gain dolby volume and a couple other features that were not available on the xx5 series.
    I have read that the HDMI switching is still incredibly slow, and some users still report delayed audio issues.
    Is there a reason you are only looking at Onkyo? I would also look at Pioneer, Yamaha, Marantz, etc.
  • Nacken23
    Nacken23 Posts: 100
    edited July 2009
    Thanks for ur advice could anyone give me specific names of good receivers in the price range of 800 to 900 euros
    edited July 2009
    Here's a UK link that lists a lot of good AVRs in pounds. You don't have to buy from this site and might be able to get a better price....but it will give you an idea for decent AVRs and their prices...
    http://www.avland.co.uk/amplifier/index.htm
    cnh
  • Nacken23
    Nacken23 Posts: 100
    edited July 2009
  • NewHTguy
    NewHTguy Posts: 584
    edited July 2009
    WilliamM2 wrote: »
    William, Hearing about your experience is disappointing. I have not had any lip sync issues. As for the stretching, a friend showed me how to do a 4/3 override on my Comcast box. But it was annoying until I learned that trick.
    OP, I'll say that you should not put the Onk 875 in a tight space. It gets really hot. Have read reviews on Amazon about them literally burning. If you have the separate amps, I would go with a xx6 model.
    The thing that bugs me is that, unless you run Pure Audio, I've heard the 875 takes an analogue signal converts it to digital and then converts it back to analogue!
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
