Bigest badest sub you have ever heard?
thuffman03
Okay,
I know I am a huge Sunfire guy. That said what is the hardest hitting loudest home audio sub you have ever heard?
My vote is for the Sunfre True sub. 2700 watts that goes down to 18Hz.
Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Post edited by thuffman03 on
Epik Conquest
Velodyne 1812?
Digital Drive 1812 Signature Edition
Specifications Digital Drive 1812
Amplifiers (Class D): 2500 watts RMS
6000 watts peak
Woofers: 18" forward firing (15.2" piston dia.)
12" forward firing (9.7" piston dia.)
Voice Coils: 3" Dual Tandem push-pull
Excursion: 1.75" max. peak-to-peak (each driver)
Magnet Structures: 690 oz. (57.5 lbs) total
Cones: Carbon-fiber laminate with ROCHACELL® center layer
Crossovers: High and Low pass, woofer-to-woofer, low pass digitally controlled and infinitely variable
Room Equalization: Yes, Digital Drive™
Sonic Presents: 6, digitally controlled, adjustable
Anti-Clipping: Yes, digitally controlled
Inputs/Outputs: Line, speaker, balanced input
RS-232 Interface: Yes
Frequency Response: 15-120 Hz, +/- 3dB
Subsonic Filter: Digitally controlled, infinitely variable
Phase: Digitally controlled, infinitely variable
Phase: Remote
Microphone: Remote
Auto On/Off: Yes, digitally controlled
Night Mode: Yes, max. output digitally controlled
High Gain Servo: Yes
Distortion: Less than 1%, all output levels
Weight: 385 lbs
Cabinet: 40" H x 25.5" W x 18.5" D
385lbs? How does one lift this thing? And there are bigger subs out there????
Well my dual Ultras will hit 120 dB plus in my listening area. Honestly, that's the loudest bass I've heard personally. I know Slowcar has quad HSU ULS15s, and I'm certain those will pump out some SPL. I've read of quad Seaton Submersives been able to pump out in excess of 140 dB in room, although I have not heard them. The Submersive resides at the top of the consumer sub woofer food chain..
Here is something I have not heard and is not a powered sub. But it certainly qualifies as BIG and BAD....Thor's Hammer (Wilson Audio).
http://hometheaterreview.com/wilson-audio-thors-hammer-subwoofer-reviewed/
cnh
Nice...Got to love a sub that is almost 400lbs.
Keep it coming....I am loving it....I want to know what else is out there!Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
My SVS PC-Ultra
Hardest hitting sub I have personally heard to date....Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Some home-made jobs a friend of mine did with 4-21" in each, trying to find a pic, but it was insane. All PA gear and powered with Crown amps. Each was about as big as a large refrigerator and weighed about 350 lbs. literally had clothes flapping in the breeze.
My SVS-PB13 UltraSpeakers: SDA-1C (most all the goodies)
I am hoping dual Def Tech Supercube Reference subs will be enough for me.
My Klipsch THX Ultra2 dual Subwoofers:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
It should be if your eardrums don't blow out first.
POLK AUDIO...DSW microPRO 4000
The subwoofer in the Bose Lifestyle V20 hits harder than anything mentioned so far.THE SYSTEM
Polk Audio LSi25 Mains
Polk LSiF/X Surrounds
Polk Audio LSiC Center
Definitive Technology PowerField 1800 Subwoofer
Parasound Classic 7100 Pre/Pro
Parasound 2205A Amplifier
Pioneer Elite BDP-05FD Blu-ray Player
Monster HTS 2600
Microsoft XBox 360
Samsung PN64D550 64" Plasma -
If you mean a hit to your ego, then yes that subwoofer would pack a pretty decent punch.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
Cerwin Vega CLS-15SPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
The subwoofer in the RCA RTD207 system throws out some frightening lows.THE SYSTEM
Monster HTS 2600
Microsoft XBox 360
Bose....Sorry you loose.
But this thread is about the hardest hitting sub you ever heard. So I will give you a pass.
Never been a fan of HTIB. I have not hear this one but like I said in the thread this is the best sub you heard. I gave the guy with the Bose a pass so I will do the same with you.
I am not ripping on anyone. Just having some fun with this and trying to see what else is out there. I love my Sunfire but I am always about knowing more!
Keep it going. The more you post the more ideas everyone has.
BTW I have been looking up the subs you guys are posting and they are very interesting. Thanks!Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
I'll tell you how a couple of Danley TH-Spuds sound sometime this summer.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
You didn't say it had to be only house subs so..........My two 15" MTX 9500's ran off two RF BD1000's
JL Audio Gotham.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I once heard dual Klipsch LF-12s in an HT config. I about crapped myself.
http://www.klipsch.com/na-en/products/lf-12-specifications/
I still want one of these, despite their documented issues. NASTY nasty sub.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I'd like to hear some Infinite Baffle setups like these someday:
http://home.comcast.net/~infinitelybaffled/page4IB-Gallery3.htmlTNRabbit
Sunfire TG-IV
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I don't know if this RCA sub blows the bose...................away -
2x Snell IC-Basis 550Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
monte kays dipole sub array
http://www.mfk-projects.com/home_theatre.htm
his ht setup is the most dynamic/effortless system i've heard!my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
concealer404 wrote: »I once heard dual Klipsch LF-12s in an HT config. I about crapped myself.
The Klipsch LF-12s are nice,but the THX Ultra2 KW-120s are the real deal.
http://www.klipsch.com/na-en/products/kw-120-thx-similar/Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Well,
That's pretty impressive if not 'overkill' slowcar. A 10' system? How big is the room?
I assume that whatever is plugged into that wall socket we can see is NOT powering that array!
