Bigest badest sub you have ever heard?
thuffman03
thuffman03 Posts: 1,325
edited July 2009 in Speakers
Okay,
I know I am a huge Sunfire guy. That said what is the hardest hitting loudest home audio sub you have ever heard?
My vote is for the Sunfre True sub. 2700 watts that goes down to 18Hz.
Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Post edited by thuffman03 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2009
    edited July 2009
    Velodyne 1812?
    Digital Drive 1812 Signature Edition
    Specifications Digital Drive 1812
    Amplifiers (Class D): 2500 watts RMS
    6000 watts peak
    Woofers: 18" forward firing (15.2" piston dia.)
    12" forward firing (9.7" piston dia.)
    Voice Coils: 3" Dual Tandem push-pull
    Excursion: 1.75" max. peak-to-peak (each driver)
    Magnet Structures: 690 oz. (57.5 lbs) total
    Cones: Carbon-fiber laminate with ROCHACELL® center layer
    Crossovers: High and Low pass, woofer-to-woofer, low pass digitally controlled and infinitely variable
    Room Equalization: Yes, Digital Drive™
    Sonic Presents: 6, digitally controlled, adjustable
    Anti-Clipping: Yes, digitally controlled
    Inputs/Outputs: Line, speaker, balanced input
    RS-232 Interface: Yes
    Frequency Response: 15-120 Hz, +/- 3dB
    Subsonic Filter: Digitally controlled, infinitely variable
    Phase: Digitally controlled, infinitely variable
    Phase: Remote
    Microphone: Remote
    Auto On/Off: Yes, digitally controlled
    Night Mode: Yes, max. output digitally controlled
    High Gain Servo: Yes
    Distortion: Less than 1%, all output levels
    Weight: 385 lbs
    Cabinet: 40" H x 25.5" W x 18.5" D
    385lbs? How does one lift this thing? And there are bigger subs out there????
    cnh
  • speakergeek
    speakergeek Posts: 555
    edited July 2009
    Well my dual Ultras will hit 120 dB plus in my listening area. Honestly, that's the loudest bass I've heard personally. I know Slowcar has quad HSU ULS15s, and I'm certain those will pump out some SPL. I've read of quad Seaton Submersives been able to pump out in excess of 140 dB in room, although I have not heard them. The Submersive resides at the top of the consumer sub woofer food chain..
    edited July 2009
    Here is something I have not heard and is not a powered sub. But it certainly qualifies as BIG and BAD....Thor's Hammer (Wilson Audio).
    http://hometheaterreview.com/wilson-audio-thors-hammer-subwoofer-reviewed/
    cnh
  • thuffman03
    edited July 2009
    cnh wrote: »
    cnh
    Nice...Got to love a sub that is almost 400lbs.
    Keep it coming....I am loving it....I want to know what else is out there!
  • beardog03
    beardog03 Posts: 5,550
    edited July 2009
    My SVS PC-Ultra
    Hardest hitting sub I have personally heard to date....
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • zarrdoss
    zarrdoss Posts: 2,562
    edited July 2009
    Some home-made jobs a friend of mine did with 4-21" in each, trying to find a pic, but it was insane. All PA gear and powered with Crown amps. Each was about as big as a large refrigerator and weighed about 350 lbs. literally had clothes flapping in the breeze.
  • thsmith
    thsmith Posts: 6,082
    edited July 2009
    My SVS-PB13 Ultra
  • blueboxer
    blueboxer Posts: 621
    edited July 2009
    I am hoping dual Def Tech Supercube Reference subs will be enough for me. :)
  • danz1906
    danz1906 Posts: 5,144
    edited July 2009
    My Klipsch THX Ultra2 dual Subwoofers:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • zarrdoss
    edited July 2009
    blueboxer wrote: »
    It should be if your eardrums don't blow out first. :D
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    POLK AUDIO...DSW microPRO 4000
  • Ethancf
    Ethancf Posts: 474
    edited July 2009
    The subwoofer in the Bose Lifestyle V20 hits harder than anything mentioned so far.
    THE SYSTEM
    Polk Audio LSiM 707 Mains
    Polk LSiM 702 f/x Surrounds
    Polk Audio LSiM 706 C Center
    SVS SB-17 Ultra Subwoofer
    Rotel RSP-1582 Pre/Pro
    Rotel RMB 1585 Amplifier
    Oppo UDP-205 Blu-ray Player
    Samsung PN64D550 64" Plasma
  • BjornB17
    BjornB17 Posts: 752
    edited July 2009
    Ethancf wrote: »
    If you mean a hit to your ego, then yes that subwoofer would pack a pretty decent punch.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • Knucklehead
    Knucklehead Posts: 3,602
    edited July 2009
    Cerwin Vega CLS-15S
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Ethancf
    Ethancf Posts: 474
    edited July 2009
    The subwoofer in the RCA RTD207 system throws out some frightening lows.
    THE SYSTEM
  • thuffman03
    edited July 2009
    Ethancf wrote: »
    Bose....Sorry you loose.
    But this thread is about the hardest hitting sub you ever heard. So I will give you a pass. :D
  • thuffman03
    edited July 2009
    Ethancf wrote: »
    Never been a fan of HTIB. I have not hear this one but like I said in the thread this is the best sub you heard. I gave the guy with the Bose a pass so I will do the same with you. :D
  • thuffman03
    edited July 2009
    I am not ripping on anyone. Just having some fun with this and trying to see what else is out there. I love my Sunfire but I am always about knowing more!
    Keep it going. The more you post the more ideas everyone has.
    BTW I have been looking up the subs you guys are posting and they are very interesting. Thanks!
  • Ron Temple
    Ron Temple Posts: 3,212
    edited July 2009
    I'll tell you how a couple of Danley TH-Spuds sound sometime this summer.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • leroyjr1
    edited July 2009
    You didn't say it had to be only house subs so..........My two 15" MTX 9500's ran off two RF BD1000's
  • TNRabbit
    TNRabbit Posts: 2,168
    edited July 2009
    JL Audio Gotham.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • concealer404
    concealer404 Posts: 7,440
    edited July 2009
    I once heard dual Klipsch LF-12s in an HT config. I about crapped myself.
    http://www.klipsch.com/na-en/products/lf-12-specifications/
    I still want one of these, despite their documented issues. NASTY nasty sub.
  • TNRabbit
    edited July 2009
    I'd like to hear some Infinite Baffle setups like these someday:
    http://home.comcast.net/~infinitelybaffled/page4IB-Gallery3.html
    TNRabbit
    Sunfire TG-IV
  • Fongolio
    Fongolio Posts: 3,516
    edited July 2009
    TNRabbit wrote: »
    JL Audio Gotham.
    +1 Serious world class controlled slam.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • rayslifecycle
    rayslifecycle Posts: 511
    edited July 2009
    Ethancf wrote: »
    I don't know if this RCA sub blows the bose...................away
  • curved
    curved Posts: 664
    edited July 2009
    2x Snell IC-Basis 550
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • SlowcarIX
    SlowcarIX Posts: 887
    edited July 2009
    monte kays dipole sub array
    http://www.mfk-projects.com/home_theatre.htm
    his ht setup is the most dynamic/effortless system i've heard!
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • danz1906
    edited July 2009
    The Klipsch LF-12s are nice,but the THX Ultra2 KW-120s are the real deal.
    http://www.klipsch.com/na-en/products/kw-120-thx-similar/
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
    edited July 2009
    Well,
    That's pretty impressive if not 'overkill' slowcar. A 10' system? How big is the room?
    I assume that whatever is plugged into that wall socket we can see is NOT powering that array!
    cnh
