Two Stereo Pairs (4 speakers)
Lsi9
Lsi9 Posts: 616
edited July 2009 in Electronics
Friend of mine wants to run 4 speakers in his store with one receiver. I know there has got to be some stereo receivers that can play both pairs at the same time (A/B). I just never gave it much thought. Can anyone recommend a stereo receiver that you know does this?
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP
Post edited by Lsi9 on
  • Conradicles
    Conradicles Posts: 6,343
    edited July 2009
    harman/kardon HK-3490 will do it with ease. Not too expensive either. Also, it has a 2 year warranty.
    That would be my 1st choice. Enjoy!
  • concealer404
    concealer404 Posts: 7,440
    edited July 2009
    Most Onkyos will do it as well. They have a feature where you hook them up as surround, but then you can select "All Static" or something of the sort, and send the same signal to all speakers.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    You could use line transformers to run speakers
    just need to match up the voltages.
    does not matter if you then operate in mono, stereo, or multichannel mode.
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2009
    all static?
    Just get a receiver that does 5 channel stereo.
    Main Surround -
  • Marty913
    Marty913 Posts: 760
    edited July 2009
    nguyendot wrote: »
    all static?
    +1 - almost all surround receivers (even the very low end) will do 5-channel stereo.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • thuffman03
    thuffman03 Posts: 1,325
    edited July 2009
    I would look for a nice integrated amplifer. Most can have two sets of speakers and you will not have to pay for all the DD and DTS logo's and will get a better amp in the process.
    How much does he want to spend? Local guy near me has 8 listed on his web site ranging from $40 to $325
    http://vintagehifipgh.com/index.php?main_page=index&cPath=14&zenid=gkvviubnlsg88ptd0lsdsrtjq7
    Hope this helps!
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Lsi9
    Lsi9 Posts: 616
    edited July 2009
    Thanks for the replies. I would have had him go with an integrated also but he seemed inpatient and went with a $300 Pioneer receiver. I did however convince him to wait for the Orb speakers instead of going for the Bose. lets see if he listened.
    Thanks again.
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
