MA500 monoblock
xj4094dg
Picked up a Marantz MA500 monoblock this weekend on e-pay for $100.
I once read these had problems with original binding posts. Anybody familiar with this? Thanks.
"The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
Post edited by xj4094dg on
i have three of them right now.. never had a problem with a binding post. but you do run into them in all kinds of used condition.. from nearly new to totally hacked to pieces.PolkFest 2012, who's going>?
Good to know... Is there any difference between the MA500 and the MA6100? I'm about to pick up two of 'em."The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
the specs are the same for the Marantz MA6100.. but it appears to be a different color in some instances. .. I think they called it champagne silver or something like that. I have never owned the MA6100.
if it's black and the specs are the same.. they it may have been a release in say Canada. I have two similar Pioneer amps.. both are identical, but one was released in Canada. and the model number is different.. even though both amps are the same.PolkFest 2012, who's going>?
danger, what are your thoughts on the amp's performance and quality? I.E. driving LSi series.TV: LG 55LW5600
Pre: Marantz SR6001
Front Amp: Parasound HCA-1000A
Center Amp: Marantz MA500
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Games: Xbox360 and PS3 -
A friend of mine was running 3 across the front driving 4 ohm GR Research AV2s. They have similar sensitivity to a LSi 9, but I'm not sure if they have the severe impedence dips. Anyway, these monos handled the load easily. I believe they are rated at 180w @ 4 ohms. Very nice open sound, but in comparison to more powerful 2 channel amps, they lack punch. They'll certainly do the job, especially for bookshelves, but if you're talking 15s, then you might want something with more current and higher damping factor.danger, what are your thoughts on the amp's performance and quality? I.E. driving LSi series.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
It would be for an LSiC, sorry I should have mentioned that.TV: LG 55LW5600
Pre: Marantz SR6001
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
as Ron Temple mentioned.. they lack punch and clairity I would say.. they power your speakers just fine.... but I think there are better ones out there. If you're budget minded like I am.. then they will be fine.. if you're looking to put out the best sound money can buy.. then you might want to consider a better more high current amp. $100 is a good price though. I think I paid $125 each for mine + shipping.PolkFest 2012, who's going>?
Well the amp will be used for my center channel which is for tv/dvd use only, I stick to 2 channel for music. Would this combo do a pretty good job for tv/dvd use?TV: LG 55LW5600
Pre: Marantz SR6001
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
I think it would work fine for a center.Well the amp will be used for my center channel which is for tv/dvd use only, I stick to 2 channel for music. Would this combo do a pretty good job for tv/dvd use?
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
