can i use a standard rca as a digital audio cablle?
goingganzo
this is my delema. i just got a new mobo and it has the new nforce chipset. with bultin dd 5.1 it has digital out spidif and coxal. now i dont have any extra digital cabbles and dont want to put the comp in the audio rack but dont want a long run for the audio hookup. for now would a regular cabble work as a digital cabble?
Post edited by goingganzo on
It should be 75 ohm...as long as it's a solid core coax cable it should be 75 ohm. If not you may have some performance issues but it's prolly not gonna fry anything, if that's what you mean.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Is that the nforce or nforce2?
