Cleaning the insides of electronics/amps
Ethancf
For components that are vented on top, I would imagine that quite a bit of dust could get inside and build up over the years, thus creating potential heat. I took the rear panel off of my Mits RPTV a month or so ago, and it was caked with dust. I blew it all out and cleaned the lenses and mirror...made a huge difference and I would imagine it could increase the life of the electronics reducing heat.
For amplifiers, pre/pros, or receivers, does anyone perform internal cleanings/blowouts from time to time? It's critical on PC's and will make a difference on your longevity for sure.
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
Post edited by Ethancf on
I do all my electronics about once a year.If...
Ron loves a film = don't even rent. -
Air compressor and a blower, but use caution, some blowers can damage internal parts if you are careless.
