BluRay with a 1080i TV
BlueFox
My TV, Hitachi RPTV 57" digital monitor and ISF calibrated, only does 1080i, and it will be a few more years before I get rid of it. Also, upconverted DVDs look fantastic on it.
My question. Is there a BIG differance in picture quality with a BluRay at 1080i versus an upconverted DVD at 1080i? I do not mind buying a BluRay player if it will be worth it, but if the differance is negligible then I can spend the money on something else.
Post edited by BlueFox on
Definately worth the purchase. The picture is great with a 1080i/720p TV. It's hard for me to watch regular dvd's after buying blu-ray.
+1 leroyjr1
My wife insists she can't see the difference but for me it was like going from regular cable, to digital cable's HD channels. I compare those channels to DVD, and as for blu ray? Well blu ray blows it out of the water imo.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
yes, yes and yes! you will enjoy blu-ray!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
You guys are trying to make me spend my beer money!!
Thanks.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
If you have the $$$ get the Blue Ray player. Make sure you get one that will do upconverting on your DVD's also. I am not up on what is out there since I am waiting for my DVD player to die before I replace it. Though most now might do that also.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
I have a Toshiba 57" RPTV set that is also 1080i, and HD content on both Blu Ray and HD DVD look fantastic. I have a Toshiba XA2 that does a great job of upconverting regular DVDs, but doesn't compare to true HD content.
Bottom line, you can't put in a picture what isn't there to begin with. -
blue,
I figure its about the sound for you. Sure a nice pic is great. Wally World has an inexpensive Magnavox Blue Ray I use with my Elite which is 1080i, like you I was a late adopter, I got my player on sale for 125.00 and it looks really good with BR and upconverts nicely. Works everytime and load times are reasonable.
I figure we will see some big price drops in the better players as all the handshaking is worked out, this thing sounds fine, looks awesome and I can wait for a fancier machine of course no self-respecting videophile would be caught dead with it as it is to BR what the OppO is to SACD players for high rez comparison.
RT1 -
reeltrouble1 wrote: »I figure its about the sound for you. Sure a nice pic is great.
Yes, both. I know the sound will be better, but I am not going to upgrade to BluRay just for better sound. The picture has to be better, and the sound is like a bonus. Of course, now I have to find a player that will decode to PCM, and make sure my AVR will accept PCM over HDMI. I would prefer not having to buy 5 high quality anaog ICs.Lumin X1 file player, Westminster Labs interconnect cable
Better sound, better picture, better get one.
do not buy the magnavox bluray player . I had one
It sucked so bad -
Hi Bluefox,
I can speak directly to this. I run an older Toshiba RPTV/HDTV with 1.1 HDMI standard and a 1080i maximum resolution. I also have a PS3 set to 1080i. And yes, you CAN see a difference between upconverted DVDs and a Blu-ray! IS it as great a difference as 1080p blu-ray...? No! But I'd say it's at least 2 x 3 times sharper, crisper image.
A simple test for you would be to view an HD sporting event in 1080i over the air then slap an S-DVD of a classic GAME in an upconverting DVD player and see what you think. Because that would be similar to comparing DVD to blu-ray on your set!
To me the PS3 delivers a sharper, cleaner more detailed picture from blu-ray in 1080i. Having said that it will be even better in 1080p...at least twice as sharp!
I did a direct comparison of Pirates of the Carribean:Curse of the Black Pearl on DVD vs Blu-ray.
The DVD played in my Sony DVD player and I let my 50" Panasonic Plasma do the upconverting to its native 1080p resolution.
The Blu-ray played in my PS3.
I manually synchronized both movies to play at the same time and I switched back and forth between the two.
The DVD at first seemed really good, then I switched to the blu-ray and literally gasped out "WHOA".
Better color, sharper resolution - no contest.
I'm surprised to see how little mention sound is getting here. A DVD has a capacity of 4.7 GB single layer and 8.54 GM double layer, while Bluray Disc has 25GB single layer and 50GB double layer...that is a huge difference! The extra capacity on the Blu ray disc is used to store a much higher quality picture and less compressed sound. The audio and sound stored on a DVD is limited due to size, where a Blu ray allows for much crisper, realistic, and life-like sound.
I noticed a HUGE difference. DTS HD-Master Audio and Dolby TrueHD are significant improvements over the sound codecs commonly found on DVDs. This is all my opinion of course, but I find the sound improvement alone to be worth the upgrade.
The picture quality is undoubtedly better, and I can barely watch DVDs anymore...but I thought I'd add the topic of audio to this discussion -
Thanks. I was not really concerned about sound since I knew the audio would be better even if my TV only did 480i. I didn't want to spend the money if the picture was not much better.
Anyway, I ordered an Oppo BD83 from Amazon. That should hold me for a year or so. Now I am ready for Watchmen, the new Star Trek, and the latest Terminator. Those will be my first new release BluRay purchases. Of course, I have to decide if I want to replace any existing DVDs with BluRay versions. Decisions. Decisions.Lumin X1 file player, Westminster Labs interconnect cable
When making replacement decisions for your dvds, make sure the improvement is worth it. Older DVD titles need to be remastered properly for the higher quality of blu-ray video and audio. Otherwise, the extra resolution just ends up exposing all the flaws in a poor quality dvd master. Read the reviews on blu-ray.com and highdefdigest.com or the tiered lists on avs to see if the PQ and AQ is worth the money before you replace.
