Monitor 10A crossover for center channel project
slack56
On the lookout for a Model 10 crossover. I am going to build a mock CS400 with a RDO 194 tweeter and two MW6501 drivers. I can create an enclosure that is up to 9"H x 20"W x 19"D. If I need more room I can go 15" on the height. Won't have the bass of my 10A's but I am hoping to end up with a better tonal balance than I am getting now with the CS400i which of course has the Trilam tweeters. Any idea's on volume or porting will be greatly appreciated. I use WinISD to build sub-woofer boxes and it has always maximized each driver I have ever built a box for. It will be hard to do with out some basic driver data I can't seem to find. Qts. Vas. Fs. dia. etc...
If I can't get some help with the driver data I may just have to use the 5JR I own. It fits perfectly in the center channel opening in my entertainment center. Question is, is the RDO 194 the correct replacement tweeter?
Post edited by slack56 on
I have two RTA 8 crossovers that'll work great for your center channel project. You would also be able to use the RDO- 194 with this crossover. What front speakers are u using.
hold off on that one Slack... PM sent...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I cannot send you a pm...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
check this thread out...
http://www.polkaudio.com/forums/showthread.php?t=84292
I am doing the same type of project now, with the same drivers. I will give you all my data as soon as It is completed next week.
JohnThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I am using late 70's, early 80's Monitor 10A's. Send me a PM???
