Home Theater Ideas -
VR3
Alright, after a few months of being in my new place and seeing what bills are going to be like - I am going to budget out a HT...
I pretty much decided I cant do this piece by piece because to do certain things I will have to do this and that and it ends up being the whole deal...
So, right now - I am guessing my budget is going to be around $7,000 -
Goal -
HT gear seperate from 2 ch ---
HDMI used as much as possible --- I only want one cable going from the receiver to the projector, is my assumption right, this is ok?
All video and audio will go through the receiver and one cable out to the projector.
Anyways --
I want a good projector 1,000-1,500 - preferably 1080p.
Motorized or manual projection screen.
Dual centers - one around the top of the screen, one at the bottom - I am thinking a pair of LSi7 mounted vertical. The top one will be upside down of course and on a B-Tech type bracket so that I can angle it.
Back surrounds only - probably LSi7 again. Same type of mounting.
Receiver will be a Pioneer Elite with at least DTS and DD 5.1 --- I do not need anything special. I need at least 3 HDMI in and 1 out. I found an older model that I can probably pick up for around 400 to 450. I am sure it will power 4 LSi7 speakers with no problems. Especially if I wire the centers in series to make them 8 ohms.
I am thinking one SVS PC+ or Ultra, will have to see where this ends up.
I am basically looking for recomendations for the projector/receiver/screen - as I am very out of the loop on all of this stuff...
Thanks in advance!
Goal -
Anyways --
Thanks in advance!
Post edited by VR3 on
I might get another Larger Sub -- but I wanted something with a fairly small footprint and kind of light weight... Larger sub does not really qualify for that one...
Anyone using the new Plus subs?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
getting HT envy
when is the Grand Opening planned ! -
Why two centers? Grab one and use the rest of the $ towards another amp."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
My $0.02 would be to use one center channel speaker and for the receiver get the Pioneer Elite SC-05. Here is a link to the product page:
http://www.pioneerelectronics.com/PUSA/Products/HomeEntertainment/AV-Receivers/EliteReceivers/ci.SC-05.Kuro
It may be a little more than you wanted to spend, but will probably be worth every penny.
Hope all goes well for you!!! -
http://www.curtpalme.com/CRTforSale_HighPerformance.shtm
Pick a projector. I've seen a few from the list and they all have a stunning image.
I'm going back to CRT myself after seeing what LCD/DLP can do (or can't do)...polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
BTW. The Epson 1080UB projector I am using is quite good for picture quality, but once I saw a G90 I was blown away.polkaudio RT35 Bookshelves
I'm not sure if wiring 2 LSi7s in series is the best move for a CC. Maybe it will work fine so try it if you already own the equipment. I do like the idea of having one above and below the screen. One benefit of a screen is you can place the CC behind it at the same height as the L/R towers. That would seem ideal. My HT was 4 LSi15s and an LSiC, but I recently replaced the LSiC with a PSB Synchrony One CC, and the differance is a fantatstic improvement. It blended right in with the LSi15s, but being 2-3 times larger than the LSiC it produces a much better CC stage, and just sounds better.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Agreed, your budget is very close to the SC-05. Not sure why you want dual centers but I would just go with one center and save some bucks or put it towards your PJ. The SC-05 will allow you to pass 1080p/24 untouched over HDMI with zero video processing. That being said you would run single HDMI cable to the PJ and be done. 1500 for a 1080p projector is very low unless you don't mind buying used. If you can stretch it, I would suggest Epson 6100, Mitsubishi 6000, or an older Epson 1080UB. Even those will exceed your budget just a tad bit but give a nice image on the "big screen". Check out projector people for the models I mentioned. If you plan to ceiling mount pick up the RPA-U mount made by Chief Mount. It's a universal mount so it will work with future projector upgrades also.
http://www.projectorpeople.com/projectors/home-theater-projectors.asp
As for screen I would suggest you go with Focupix or Elite, tab tensioned screen so you avoid any "waves" later on. The screens are of good quality with an excellent price. Stewart screens are considered reference, and their tab screens will cost upwards of half your budget. So check out HTDepot or Projector People and go for 16:9 screen, tab tensioned shown here. I think the 106" screen would work well with the projectors mentioned also. Since you're going with new model projector I would suggest Matte White screen as most new PJ's today have good black level performance.
http://www.htdepot.com/Focupix_TensionFlat_16_9_Electric_Screen_105_p/fxt169s-106.htm
http://www.projectorpeople.com/screens/screendtls.asp?manu=Elite&itmname=CineTension%202%20Electric%20Screen
Hope this helps you out somewhat.Shoot the jumper.....................BALLIN.............!!!!!
If the G90 blew you away, then the JVC Series will do no less my friend. Digital is really good these days.Shoot the jumper.....................BALLIN.............!!!!!
I would have Tyler build you a matching center, timbre is important."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
That would be really sweet...:cool: -
I don't like your two center speaker either, well if you're set for two centers I believe they need to be in the same horizontal line. Having one low, and one high would diffuse the sound of the center channel.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Edited
I've seen the HD1/RS1 and it was an incremental step up from the Epson, not sure about the new units though.polkaudio RT35 Bookshelves
disneyjoe7 wrote: »Having one low, and one high would diffuse the sound of the center channel.
I was thinking they would complement each other, and make the sound seem to come from the whole screen. On the other hand, you very well might be right. It would be nice if AVR manufacturers included two CC amps for just this purpose, or let an unused rear amp be reassigned to CC duty.
I wonder how well that would work having 2 CCs, even if both were along the bottom, or top?Lumin X1 file player, Westminster Labs interconnect cable
DarqueKnight would be the one to pose this question to. His are side-by-side. -
ProjectorPeople has Epson 1080 for 1599, it's listed under demo models, definitely worth a look.Shoot the jumper.....................BALLIN.............!!!!!
In many cases Polk speakers uses High impedance cross over therefore I believe you could set your centers in parallell (when this is the case) without being a threath to the receiver. I don't think setting them up in series would be a good idea. I was also thinking of doubling the center and some other channels to back-up effects such as helicopter or other sounds met tocome from above???I was thinking they would complement each other, and make the sound seem to come from the whole screen. On the other hand, you very well might be right. It would be nice if AVR manufacturers included two CC amps for just this purpose, or let an unused rear amp be reassigned to CC duty.
I wonder how well that would work having 2 CCs, even if both were along the bottom, or top?DARE TO SOAR:
If you wired two LSi7 in parallel it would be a 2 ohm load...
In series it is 8 ohms ---
Not really a difference...
Thanks for all the input guys.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I have one center below the projection screen and it seems fully adequate. Depending on what sources you are running through the amp, you might want to put in extra cables to the projector. For instance, I have S-Video running since I have an old VCR (That's Video Cassette Recorder for those who have forgotten what that technology was
) and my WII outputs are currently composite. Some Elite amps will upconvert signals so that you only need the HDMI. I also ran a single CAT 6 cable and left it in wall above the projector as future proofing in the event that some new technology comes out and I can't get back in the ceiling again (it could also be used as a pull cable if need be). ____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
If I go through Ty --
I will just get a single Super Tower for the center - I will either go A) half **** or
all the way...
Center channels are the biggest waste of money in this hobby...
You pay the same price for one speaker as you do for a pair and no one even sniffs at it funny...
I refuse to pay for marketing... lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You're exaggerating a little, but I know what you mean. If it makes you feel better, a good center is not a tower a bookshelf or tower turned on it's side. There is additional R&D needed, plus they only sell half as many, so they have to make their money back somehow.
Yeah - but the ONLY reason there is additional R&D is because the speaker is horizontal and not vertical...
If you take a single bookshelf, keep it vertical and mount it where you center is... you wont miss a thing...
Now if you took a LSi9 and set it on its side and then took a LSiC and put it in its place - sure there would be a difference...
But if I were to take a LSi9 and left it vertical and mounted it where a center woul go -- I bet it would walk circles around a LSiC in width and midrange clarity...
I hate to talk **** about centers - they have a place in this hobby, but not in my system. I will run phantom before spending that kind of dough for one speaker... lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Usually, it depends on the driver arrangement and crossover.Vr3MxStyler2k3 wrote: »If you take a single bookshelf, keep it vertical and mount it where you center is... you wont miss a thing...
I hear ya, I've had a phantom setup for a couple years now and probably won't go back.I hate to talk **** about centers - they have a place in this hobby, but not in my system. I will run phantom before spending that kind of dough for one speaker... lol"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
