Cheap Adcom GFA-555-buy it?
jimbo1421
Hello,
There is an Adcom GFA-555 here for sale-$50. The ad says that it is 20 years old. I would use it to power a pair of Monitor 10s or 7s now but looking ahead I would like to run a pair of SDA-2s with it. I cannot find anything that says for sure that it is a common ground amp; a quick search of the forums shows that some people use them on SDAs. Is it a common ground amp?
Cheap as it is, the age still bothers me a bit. I don't really want to spend $50 on a pile of trouble. What should I beware of when inspecting the amp that should wave me off? Can anyone give me an idea of the cost to refurbish this amp?
Thanks,
Jim
Thanks,
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro
Post edited by jimbo1421 on
There are plenty of repair shops that can fix for not a lot of $$$ if there is a problem. I would pick it up and get it up and running.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
I have one not much younger than that....those things are almost indestructible...and in all likelihood all it needs are some new caps...if that! As George says, you should touch base with Ben.
If the amp is in need of work you'll know....by how it sounds and if there is a HUM, etc. For 50 bucks you can't go wrong, even if in need of some repairs and I doubt many....unless someone dropped it a couple of stories....those Adcoms are built like TANKS!
Cheap and Adcom, goes together like Peanut Butter & Jelly.
RT1 -
Thanks guys. What about "common ground"? I never see this called out in any specifications listed for any amp that I have looked at. How can I tell?
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
The 555 is common ground. No worries there._________________________________________________
Thanks, Ricardo. How does one tell if any particular amp or receiver has a common ground?
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
Take a multimeter and measure resistance (ohms) between the two negative (black) posts in the back of the amp, with the amp off. If you read 0 or very close to 0 (0.1, etc), it's a common ground amp._________________________________________________
you buy it. now.engtaz
Did you hear the one about the Adcom and the NAD.
Well an Adcom and a NAD go into a bar.
They slide up a stool and the Adcom's IEC cord falls out.
A stranger walks by and picks up the Adcom's power cord and slides in back into the connector.
The Adcom says oooh that feels better, thank you very much, my power cord is always falling off like that, my tail is a bit loose you see. The stranger says no problem, and by the way here is your cap as well, it fell off when you came in.
The NAD amp simply shakes its head and says If your Caps are Off and your Bottom ain't Tight you can believe its an Adcom thats not right.
RT1--you hear me. -
Eh,, is that a NO,,, Ted;)JC approves....he told me so. (F-1 nut)
naw, I am just busting on Adcom recently, next week I may move on off the A's, lets see what starts with B is an audio product and not worth crap.......oh well, now there is a tough one.
I do have to admit the Adcom guys (especially Brock) refused to let me pick the scab., but I KNOW its secretly killing him not to say its a Pass Design.
RT1 -
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
Seems like a no brainer at $50.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
reeltrouble1 wrote: »Did you hear the one about the Adcom and the NAD.
RT1--you hear me.
Nice one...we could all use a bit more humor here...especially of late?
Somebody else snagged it.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
Jim
No surprise. I see GFA-555II locally for 250, and everybody thinks it's cheap... but for $50!!!! holy moly. I am surprised you had time to post here and it was still available.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Those amps are usually good to go at 300+ dollars! So anything less than that is a bargain. Like Reeltrouble says above Adcom and cheap is like P&J.
At the same time, if you're making your first steps into external Amplification you can't do much better than this at this price. A new Adcom is 1200+ dollars and the 555 is considered a superior design to the NEW models! I'd prefer to say 'value' rather than cheap. Because, one man's cheap is another's mid-high End.
The seller didn't reply to me yesterday and sold it to his neighbor this morning. Nothing like being on the spot when a deal like this comes along.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
Makes you wonder why he didn't just talk to his neighbor first instead of advertising?
