looking for speakers
yamaha man
yamaha man Posts: 1
edited June 2009 in Speakers
can you buy monitor 70's anywhere or what would be a good match? I have a yamaha v-661 7.1 reciever
  • Ender
    Ender Posts: 603
    edited June 2009
    Good match of speakers to receiver?
    That will do fine, I suppose. And yeah, I believe the Monitor 70 are widely sold. Comes with the department of being a lower-end Polk.
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • Osarion
    Osarion Posts: 192
    edited June 2009
    Newegg has them http://www.newegg.com/product/product.aspx?Item=N82E16882290016&CMP=AFC-C8Junction
    And you can knock $50 off by using promo code:SPEAKER63X5 (It's only good for the Cherry I believe)
    I believe the code is only good for one speaker per account, so create 2 accounts and get the $50 off both speakers. I did that when I ordered my M60's and it worked with no problems.
