gfa-585 on it's way out
Me Myself & I wrote: »sorry but no it will crap out after say 30 p/ch like the main caps are out of power when i try to push for more then the 30 the speakers will fluter with high distortion but at very low volume on sound till i turn it down. i do know what this amp is able to do and i was only using a 8 ohm load per /ch 2 18" blackwidows 4" voice
Have you checked the DC offset. Not trying to be rude but it sounds like you really have little to no experience in repairing electronic equipment. If that's the case take it to a qualified technician.
You don't mention anything about what components you've measured/checked up to this point and the whole "channel inversion" comment leads me to believe you shouldn't be repairing this yourself.
I recommended where to start, with the caps leaking. You can't always tell by the naked eye if they are leaking, if the amp as high DC offset then that's likely that's where to start.
Again I ask, do you have a schematic of the amp? Smelling an visually inspecting really won't tell you much if anything. You already know something is wrong.
These amps sure seem to break a lot.
RT1 -
to all you people busting on the op's english, the feeling I get is that they are not native english speakers and are trying to speak as good as they can.
instead of making snide remarks, how about trying to interpret what you can and then tell the OP what you think and then he can clarify it.
geez
