Amps for Atriums
mdaudioguy
mdaudioguy Posts: 5,165
edited June 2009 in Electronics
I'm looking for a couple of amps to drive two sets of Atrium 55's (1 pair on a deck, the other below). I need two 2-channel amps, because I'll usually only run one pair at a time. I want affordable, preferably in this price range:
http://www.amazon.com/Dayton-APA150-150W-Power-Amplifier/dp/B000VKXLBO/ref=sr_1_2?ie=UTF8&s=electronics&qid=1246219254&sr=8-2
http://www.amazon.com/AudioSource-AMP-100-2-Channel-Bridgeable-Amplifier/dp/B00026BQJ6/ref=pd_cp_e_1
My only real requirement (besides good sound, or course) is auto-on capability so that when the attached squeezebox receiver is activated, the amp will power up.
I also ran across this:
http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1251381513&/Sherbourn-LDS-2/75-Amp
Comments, suggestions? TIA!:)
Post edited by mdaudioguy on
  • mdaudioguy
    edited June 2009
    Bueller... Bueller... :confused:
    Ok, how about the Tweak City Audio Gizmo? Anybody used one of these? My only concern is that I don't think it has auto-sensing inputs.
  • jimmydep
    jimmydep Posts: 1,305
    edited June 2009
    If you have room in your budget this might be a good choice
    http://cgi.ebay.com/SUNFIRE-SZA-2200-SECOND-ZONE-200-WATTS-PER-CHANNEL-AMP_W0QQitemZ260435245055QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ca32677ff&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1234%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
    The Atriums are good sounding speakers, my only question is do you need to drive them to high volume or just to a moderate listening level?
    Jimmy
  • mdaudioguy
    edited June 2009
    Thanks. I've seen a lot of options out there in that price range, including several older models on A-gon (but I don't think many have the auto-power feature), but I'd prefer to spend no more than $150 per amp (I need two).
    To answer your question, I'd say moderate listening levels, assuming we want to continue living in this neighborhood... and we do!:) I know that with a decent amp, even moderate levels should sound good.
  • jimmydep
    edited June 2009
    mdaudioguy wrote: »
    The reason I ask is I'm able to drive my Atrium 65's to moderatly high volumes using my 90wpc receiver, when I connect them to a 200wpc Sunfire amp I don't notice a significant change in the sound quality at the same volume...........I can't raise the volume any louder for fear of retribution from the neighbors.
    Jimmy
  • Monster Jam
    Monster Jam Posts: 919
    edited June 2009
    In my humble opinion, if your driving Atriums with anything more than minimum, your wasting your money frivolously.
    Do you hear that buzzing noise? :confused:
  • mdaudioguy
    edited June 2009
    Thanks for your comment MJ. When you say minimum, are you referring to the Polk recommended amplifier power of 10-100 wpc for the Atrium 55's? Also, why do you say that?Is it efficiency? Is it because of the sealed design? I'm curious, because I think I need a little something more than a 10 wpc amp, or maybe that's not what you meant.:confused:
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2009
    Just get a cheap Adcom GFA535....you don't need a lot of power for the Atrium series. Out of the 3 you linked, I'd pick the Audiosource.
  • jimmydep
    edited June 2009
    I agree, save your money and run them off the receiver.
    Jimmy
  • mdaudioguy
    edited June 2009
    jimmydep wrote: »
    Jimmy
    That's my dilemma — I won't have a receiver in the mix. Squeezebox is an unamplified source. Older, used amps don't have auto-power on and off, so maybe AudioSource is the way to go.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2009
    Audiosource for the auto/sensing and cheapness factor. They actually do a pretty good job. I've seen the Amp 100s for less though. The Amp/One A sometimes gets down that low in price (or Amp 200). The Amp/One A has independent gain controls and can be used like an integrated...another plus.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • mdaudioguy
    edited June 2009
    Ron Temple wrote: »
    Ah ha! An Audiosource owner! I checked out the specs, and btw, their specs are SCREWY... Anyhow, the thing that makes me think twice about the 100 is 1% THD, vs .04% for the One A... seems significant enough to pay a few dollars more. Thanks Ron.:)
