Active vs passive SDA's
ben62670
Active kills passive in all ways period.
Ben
Ben
Post edited by ben62670 on
You're talking crossover, right?SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
Yes.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
You mean you don't like power robbing and coloring passive components? Say it ain't so?
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Testing
Testing
Testing -
Sure they do sound better, but in reality hardly anybody will do that. Glad to hear yours sound great.
What kind of active Xover do you use...a DIY? -
Guys it is about the SQ. I have tried many caps. Inductors suck. Read about them. Big deal the extra amp for the highs cost less than the upgrade parts some of you pay for. You don't need 200wpc on the highs!
Also If I had the coin I could run tubes on the highs.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Conradicles wrote: »Sure they do sound better, but in reality hardly anybody will do that. Glad to hear yours sound great.
Come down.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Not only do the coils and caps color the sound, they also create unneccessary loads on the amplifier.
Actively crossed over electrostatics? *drool* Now that would be a treat. -
When I can afford 4 or 6 channels of quality tube amplification, I'm in."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
You should just build one! -
With availability and size of chip amps, wouldn't it be easy to just install a few in a speaker and make them a true powered design? Then all you would have to do is run ICs from your electronic XO to the speakers.
If I found a kit that I knew would sound as good as what I'm currently using, I would consider it. Otherwise, too much time and $$$ to take a chance.You should just build one!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
PE sells a 2way active xover/ amp combo that can be mounted into the back of an enclosure.( like a plate amp on a sub).It uses a pair LM3886's for amplification.Mated with a decent woofer and tweet could make for a nice little monitor or PC speaker.Testing
Testing
Testing -
I will never go back!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Couple questions:
1) Is an active crossover external?
2) If speakers already have their own internal passive crossover, there's no way to bypass them, right? So that means you can only use active crossover on speakers without a crossover network?SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Yes it's electronically similar to a preamp but with specalized filters for the crossover functions.Couple questions:
There are a few DIY designs that combine active and passive xovers but the big benifits of actives are achieved when passive components are removed allowing for a direct connection between the amplifier and drivers.The down side is complexity as an amplifier channel is required for each individual driver.2) If speakers already have their own internal passive crossover, there's no way to bypass them, right? So that means you can only use active crossover on speakers without a crossover network?Testing
Testing
Testing -
It would be pretty easy to bypass or remove an internal XO if you wanted to use an external electric. The only down side is you would have to add binding posts for each driver or set of drivers; although this would be ideal if you have a speaker that is a two way design and bi-amp binding posts.
