Music File Compressed 1,000 Times Smaller than MP3
BigMac
BigMac Posts: 849
edited June 2009 in The Clubhouse
This is an interesting idea but the technology has a longgggggggggggg way to go. Mp3 imo sucks the life out of the music and this compression just degrades it to the point of sounding like complete crap. What do you think?
Copied from the Rochester.edu website:
Researchers at the University of Rochester have digitally reproduced music in a file nearly 1,000 times smaller than a regular MP3 file.
The music, a 20-second clarinet solo, is encoded in less than a single kilobyte, and is made possible by two innovations: recreating in a computer both the real-world physics of a clarinet and the physics of a clarinet player.
Takes about 5-10 seconds to buffer depending on your connection.
Human performance recorded using MP3 format: http://www.rochester.edu/news/audio/Clar_orig.wav
Virtual performance using Bocko's new compression: http://www.rochester.edu/news/audio/Clar_synth.wav
Link to entire article: http://www.rochester.edu/news/show.php?id=3136
Post edited by BigMac on
    treitz3 Posts: 20,069
    edited June 2009
    I think that I never want to hear what it would sound like.
  • bobman1235
    bobman1235 Posts: 10,822
    edited June 2009
    From a brief skim of it, it sounds more like they're recreating a sound rather than storing it. Almost like the way a MIDI file works.
  • sucks2beme
    sucks2beme Posts: 5,690
    edited June 2009
    Next thing you know they'll come up with a method to encode it
    into grooves on a soft plastic like surface............
    edited June 2009
    Sounds like a musical form of TWITTER! What's the fewest number of characters you can use to communicate about nothing?
    cnh
