What amp for SDA-SRS2's
Polkie2009
Polkie2009 Posts: 3,834
edited June 2009 in DIY, Mods & Tweaks
What's a good choice in a used 2 or 3 channel amp that can push about 250 watts RMS a channel at 8 ohms? I know the big Polk mains aren't 8 ohm speaks. I also see where the amp needs to be common ground if I use the interconnect cable. Any thoughts on Carver,B&K, Ashly FET's, Monster, Adcom,Hafler and others?
Post edited by Polkie2009 on
  • xsmi
    xsmi Posts: 1,804
    edited June 2009
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • Face
    Face Posts: 14,340
    edited June 2009
  • Polkie2009
    edited June 2009
    Thanks for the quick replies,after posting here I realized I might have put this in the wrong section, if I need to move it I don't know how to do that,lol. I should have added I wanted to keep the price under $500.00. I've heard good things on that certain Adcom model:)
  • maandjojo
    maandjojo Posts: 293
    edited June 2009
    I am using the Adcom 555II and it works great. Adcom has always been one of the best medium priced high end amps in the business. You can't beat these relics, and they are always available on ebay or polk classifieds.
    Joe
    Joe
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2009
    xsmi wrote: »
    +1for the Adcom 555II which has plenty power for your SRS2's. Also the amp is mine. Maybe we can work out a deal.
  • thsmith
    thsmith Posts: 6,082
    edited June 2009
    Carver TFM-45
    The TFM25 works well too. I think it is 250wpc at 8ohms. The 45 is 375@wpc.
    Not that WPC matter
  • mewisemagic
    mewisemagic Posts: 194
    edited June 2009
    leroyjr1 wrote: »
    that's a good deal for that set up:)
    nooshinjohn Posts: 25,991
    edited June 2009
    Sunfire works well also...
    Tony M Posts: 11,690
    edited June 2009
    I was just saying in the other thread alot of of fine amps can be bought for up to 500.00. Sorry if it came off sounding like 500.00 was your budget.You'll find Adcom and Carvers' are liked hear on the forum.Good luck again
  • mewisemagic
    edited June 2009
    look here, 200 watt/7ch. sunfire. you could bi-amp with the xtra channels http://www.carveraudio.com/phpBB3/viewtopic.php?f=18&t=8455
  • Polkie2009
    edited June 2009
    Lol, Tony, I was kinda wanting to keep the budget under $500.00 til I started looking at used amps that can be had at for around $800.00 Jeez, decisions,decisions....
