vinyl door panel rattles
chu
What can you do to stop the door panels from rattling??? I was thinking of adding a layer to the vinyl/plastic panels, but do people actually do that? I already deadened the metal parts just not the vinyl/plastic panels.
Post edited by chu on
whoops, i guess I should have proof-read my post before submitting. Well I was thinking of adding a layer of sound deadeners to the door panels, but I'm not sure if there is another solution that I can do to stop the rattles.
I guess people do deaden panels as well, thx!
use it on the vinyl panel too, u can never have enough deadener material
but i have RAAM Audio..
http://www.raamaudio.com/cgi-bin/index.cgi
the product is way better and also cheaper than Dynamat Xtreme wich I also have..
I use some Ensolite also, and worked very well
http://www.raamaudio.com/cgi-bin/index.cgi?p=prZ
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
