Idea for CD player "preamp"
wizzy
wizzy Posts: 867
edited June 2009 in Electronics
I woke up today and was thinking about my preamp. I am looking at replacing my CD player (which has a volume control, an older Denon) with a CD player that doesn't have this.
So anyway, most CD players have plenty of power to drive the amp to clipping if plugged straight into the amp.
I'm laying in bed thinking about this earlier today.
Instead of using a pre-amp, why not just build a simple box that has a high quality potentiometer in it to adjust the level of the CD players output ??
Walla - no electronics, no power supply, no big long path of crap between the CD player and the amp.
Surely if someone would build something like this people would buy it.
Post edited by wizzy on
  • thuffman03
    thuffman03 Posts: 1,325
    edited June 2009
    Interesting idea. I don't know much about what you want to do so I will defer to some of the other members to say it is a good idea or not.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
    heiney9 Posts: 25,497
    edited June 2009
    wizzy wrote: »
    There are several. One of the best is the Pass Lab B1 buffer and I believe Promethius makes one, as well as half a dozen other companies make a passive line level controller.
    My pre also runs in passive mode. The signal sees the input switch and the vol control and that's it when in passive.
    Be careful not all systems (nor recrodings) like a completely passive controller. Components have to be choosen carefully.
    http://www.enjoythemusic.com/magazine/equipment/0407/promitheus_audio_tvc_se.htm
    http://www.enjoythemusic.com/magazine/equipment/0708/first_watt_b1_preamplifier.htm
    P.s. I love the advantage of my pre to run passive or active by the flip of a switch.......best of both worlds and I enjoy bothe settings equally depending on the recording.
  • shack
    shack Posts: 11,154
    edited June 2009
    They already exist. Here is the VPC•3 Passive Controller from Channel Islands Audio.
    http://www.ciaudio.com
  • Face
    Face Posts: 14,340
    edited June 2009
    http://www.goldpt.com/index.html
    I agree with H9 that they don't work in every setup.
  • dkg999
    dkg999 Posts: 5,647
    edited June 2009
    Creek also makes a pretty nice little passive pre/volume control. The CIA one is also supposed to be a very good one.
    IMHO sometimes a little colorization by the pre is not such a bad thing.
    DKG999
  • wizzy
    wizzy Posts: 867
    edited June 2009
    Ah ... well, I'll have to check those out.
    I don't really understand why they call them "passive preamps" as they aren't preamping anything. The term passive controller (CIaudio) seems more proper.
  • Face
    Face Posts: 14,340
    edited June 2009
    Since when is "preamp=before amp" so hard to understand?
  • wizzy
    wizzy Posts: 867
    edited June 2009
    Face wrote: »
    Interesting, I always thought of it as signal pre-amplification ... the amplification of the signal occurring before the larger amplification of the signal in the amp.
  • Systems
    Systems Posts: 14,872
    edited June 2009
    wizzy wrote: »
    Like this?http://www.polkaudio.com/forums/showthread.php?t=84442
    Testing
    Testing
    Testing
  • venomclan
    venomclan Posts: 2,467
    edited June 2009
