Keep blowing tweeters
Hi Everybody,
I am about to buy my third tweeter for my left SDA-2Bs.
Why does this keep happening?
Could this be a crossover problem?
Any help would be much appreciated.
SDA-2B in front
RM-3000 in rear
CS-400I/CS-175 front/rear center
Yamaha RX-V1 receiver
Sony DVP-NS700P progressive DVD
Yamaha CDC-100 CD player
SVS 20-39 PC-PLUS subwoofer
47" Mitsubishi HD 16:9 rear projection
RCA DTC-100 hi-def receiver
Canare component all over, and optical for audio. Zerosurge keeping the peace for power surges.
Office:
Nakamichi TA-2A receiver
Cambridge Audio D300-SE CD player
LSi9 "bi-wired" (A+B getto style) with Canare quad and banana terminated.
RM-3000 in rear
Office:
Post edited by agioino on
Do you listen at obscene levels? You strike me as somebody that knows what they're doing but just making sure.
A better place for this thread might be in troubleshooting. -
Oops!
I hope posting here doesn't get me in trouble.
Some sites are kinda nuts about this.
I figured speakers?
Anyway, I guess I listen at crazy levels sometimes, but probably not obsene levels. Although, sometimes demos and alcohol...
No but really, it always the left for some reason.
Thanks for the forum tip.SDA-2B in front
RM-3000 in rear
Office:
LSi9 "bi-wired" (A+B getto style) with Canare quad and banana terminated. -
No, we're not that anal about it, you would just get better help in troubleshooting as it's checked up on by Polk CS and they would have more knowlege of any common issues and what to do about them.
If it's always the left, then it could be just dumb luck, but it sounds like something is definately not right about it. -
Of Course something's not right about it! It's the Left Speaker!
ok, sorry...
If it's consistantly the Left Speaker, perhaps that channel in your Amp is going bad and dumping a lot of high-frequency energy into the speak. Or the x-over in that speaker is bad. There's got to be some asymmetry.
Just a guess. -
Originally posted by PhysicsCoder
ok, sorry...
You better be
Do you suppose I get two new crossovers as well as two tweets so that EVERYTHING is matched?SDA-2B in front
RM-3000 in rear
Office:
