CS1 or CS2 with Monitor 50s and Denon 1910
So, I am working on a budget system and just bought Monitor 50s for my fronts to go with my new Denon 1910. Newegg is having a sale on the CS2 but the CS1 is recommended for my setup here. I will be using some crappy Magnavox surrounds and a powered Magnavox sub for now as I need to save up a bit before I get those next two pieces of my setup.
Any reason I shouldn't go with a CS2 with my setup? I have a smaller living room and will probably do 80% TV/movies and 20% music.
Denon AVR-790
Samsung 40" LCD HDTV
Samsung DVD
Fronts: Monitor 50s
Center: CS1
Samsung DVD
Fronts: Monitor 50s
Center: CS1
Post edited by bp_ on
Forget the recommendation and Go with CS2. For TV/Movies center channel is used a lot, so you should always try to get the best one in your budget.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
+1 on the CS-2. Having owned them both, the CS-2 is much clearer for dailogue. It's rather large, but if you have the room go for it.
I got a referb CS1 shipped for $75 from polk and it works great with my Monitor 50's I don't see me paying the $50 more for the CS2. For me that $50 is better off going elsewhere in the system, but that is me.
IMO, I think the soundstage with your set-up would sound much better with the CS1, a little more natural if you will. although I dont use a CS1 for my center Ive heard several and they are very nice sounding centers. Sounds like you will be keeping your current set-up at least for awhile.....go for the CS1.
Enjoy, David.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
I just got my Monitor50's yesterday and they sound great with my CS1. I haven't heard the CS2, but I can tell you that I'm sure you won't be disappointed with the CS1.
I asked someone a while back and was told the CS1 is a slightly better match with the Monitor50's compared to the CS2, and that's why I went the route I did. And personally I have no regrets about my choice.
Good luck! -
The only reason u don't wanna go with CS2 is Size. Its bigger than CS1
Living Room: 7.3: Samsung - LN52A750, Pioneer Elite SC07, logitech 880
Def Tech Mythos ST
Fronts, Def Tech Mythos 10 Center, Def Tech BP-30 Surr, Def Tech Mythos GemXL SurrBack, MartinLogan Dynamo
2Ch: Carver TL-3200 CD player, Carver CT-17 pre, Carver TFM-45 amp driving SDA-1C
Bed Room: Pioneer Elite VSX-52 , Monitor 50
Storage-RTi8,CSi5,PSW505,Monitor50 -
thanks all, the size of the CS2 is a concern. I think I'll keep an eye out for a good price on a CS1 for a bit.Denon AVR-790
Samsung DVD
Fronts: Monitor 50s
Center: CS1 -
I saw one on Polk/Ebay for $50.00.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I would still strongly recommend the CS2 if you can find the room for it. It's worth the extra price and size. I've owned the CS1 and CS2 (still have the CS2 in my bedroom rig). The center channel is one of the most important speakers in a home theater set-up. Approximately 80% of the dialogue in most movies is output through the center channel. There often sequences in a movie where the center channel is the only speaker outputting sound. The CS2 was much, much clearer for dialogue to me than the CS1. There were oftern times I would have to rewind a scene because I couldn't understand the dialogue with the CS1. I did not have to do this nearly as much with the CS2. Dialogue is much more noticable and lifelike. It also sounds better for multi channel music if you like listening to that.
The only drawback of the CS2 is that it is much bigger. If you plan on keeping the Monitor 50's for a long time than do them justice with the CS2. If you plan on upgrading sometime soon than get a cheap CS1. The CS2 is able to anchor the whole system with the 6.5" drivers and larger box. Deep voices and explosions requiring more ouput are much more clear than the CS1. The CS2 will not overpower the Monitor 50's at all. It is slightly more efficient and will play approx. 2 Db's louder. If you are finishing your whole setup with monitors than don't wonder what if and get the CS2. With a preference of 80% tv/movies you will be using the center quite a bit and considering the cost of all the other equipment that goes along with HT the extra $50 or so on the most important speaker would be a good idea.HT Setup: Onkyo 706; Rotel RB-1075; Rti A3; Csi A6; Fxi3's
2 CH: Squeezebox Touch; Dared SL-2000a; GoldenEar Triton 5 or Lsi9's; Parasound 2125; SVS SB12-NSD; Music Hall DAC 25.2 -
well said cdn
Def Tech Mythos ST
The bigger center channel is ALWAYS going to be a better choice. There's absolutely no reason that a CS1 would blend better with the Monitor 50's than the CS2. All of the drivers are timbre matched, so can be mixed however you please.
The center channel carries over 50% of a movies soundtrack, and is really THE most crucial speaker in the whole setup. A bigger center channel is going to carry the soundtrack a lot more efficiently, and blend much better with the mains and the sub.
That being said, yes, it is big. So make sure you've got room for it.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Im just going by what Ken at Polk Audio chat told me.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I just got the CS2 yesterday and sat it above my tv and unless your looking right at it It dosen't look that big. When I opened the box the wife went Oh my god. Now it's hey thats not bad at all. And it sounds good with M60's and M40's Good luck on your choice.
potee -
I'd say CS2. The 6.5" woofers add to the midrange and bass.
The CS2 now only $119.00 at newegg Get it. While you can. They even gave me a rebate on mine that I got yesterday.
potee -
I've had both, just bought a CS2 about a month ago to replace my CS1. There is a difference although it is not huge, at least to my ears. However its probably better to go with the better speaker, the CS2.
I appreciate all this feedback...makes the choice a little more difficult. I guess I will do some measuring to see if I can fit the CS2 into my setup.Denon AVR-790
Samsung DVD
Fronts: Monitor 50s
Center: CS1 -
Def CS2 with M50s.
Miike____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
Mike, I had the same front stage as yours with 805. I loved it and missing my 805 now.
Def Tech Mythos ST
