How close (listener/speakers)?
organ
organ Posts: 4,969
edited June 2009 in 2 Channel Audio
Just wondering what everybody's preference is when it comes to speaker distance between listener and speakers.
I have never liked the presentation of any of the speakers I've had in my set up when the speakers are 8ft away from me or closer. Everything was just too close and there is less bloom at that distance for me. I've always preferred about 10ft. I'd love to go for more but they would be too close to the front wall. I am using the long wall of an L-shaped room.
So just checking what your preference is.
Post edited by organ on
  • Mike21
    Mike21 Posts: 252
    edited June 2009
    My preference is whatever distance produces the best sound.
    Mike
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • Face
    Face Posts: 14,340
    edited June 2009
    Near and mid-field do have their advantages, but I normally wouldn't recommend it with a pair of full range towers. Sometimes a distance of 8+ is optimum, but it boils down to personal preference, room, gear, etc...
  • pearsall001
    pearsall001 Posts: 5,324
    edited June 2009
    I'm at 12' from my monitors in a 32' room. Sounds great to me!
  • BlueFox
    BlueFox Posts: 15,250
    edited June 2009
    I move my recliner in closer or out further to vary the sound, and provide some variety. Triangle wise in close is about 6-7' sides with the base around 9' (speakers are out opposite ends on the base), and out could be 10-12' with the same size base. While it sounds good in either spot, I find myself preferring in closer more than further out.
  • thsmith
    thsmith Posts: 6,082
    edited June 2009
    SDA 1Cs 7' apart and I sit about 14' back.
  • Polkitup2
    Polkitup2 Posts: 1,642
    edited June 2009
    Speakers 6 feet apart and sit 8 feet back.
    heiney9 Posts: 25,492
    edited June 2009
    My SDA 1C's are about 7 feet apart and I sit dead center (there's a slight dent in my leather couch where the sweet spot is) about 7 feet away or so. Sounds fantastic.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    Polkitup2 wrote: »
    Speaker are 6' 6" apart. The sweet spot is 6 to 8' back dead center.
  • Flash21
    Flash21 Posts: 316
    edited June 2009
    That is roughly what my set up is too, but I cannot really move further back even if I wanted to; my living room is modest size and I have the system on the long wall.
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • rubin
    rubin Posts: 565
    edited June 2009
    speakers 8' apart, 22' back EXTREME BOOM,....... 6' to 8' back is ok, 12' is best (in my room)24'long with widths varying from 10 to 16' plus an opening to a small summer kitchen.And a stairway.
  • hearingimpared
    edited June 2009
    Flash21 wrote: »
    My room is 20' x 11' 6". I have my speakers on the long wall as well. My sweet spot is perfect.
  • Systems
    Systems Posts: 14,872
    edited June 2009
    There is software out there to take all the fun out of placing your speakers for best performance. When you take into account listener position and height, room size, room treatments, items actually in the room, carpet and so on the game gets somewhat more fun. Since sound moves in a waveform across the room and reflections are to be accounted for, you can go all out OCD on this subject. I would agree that the best advice would be to experiment with the placement to best suite your listening pleasure. Only you know what sounds best to YOU.
    Testing
    Testing
    Testing
  • venomclan
    venomclan Posts: 2,467
    edited June 2009
    I prefer to be within 6 ft. Nearfield just comes through cleaner without boucning off the room before it hits the ears. It actually depends more on the speakers themselves imho. My B&W's would project an image 2 ft out, while my Gallos put the sound 2 ft. behind, creating a much better soundfield.
    Venom
  • Systems
    edited June 2009
    venomclan wrote: »
    Venom
    This is a classic example of wave form patterns with speakers.
    Testing
    Testing
    Testing
  • rru2s
    rru2s Posts: 90
    edited June 2009
    My living room has furniture along all the walls, so when I want that perfect stereo sound, I sit about 11 feet perpedicular distance to the plane of the speakers along the far wall, which are about 1.5 feet from the corners and separated about 13 feet. But I just received two more monitor 70 towers so I'll find out later today where the overall sweet spot is, since the rear signal will be identical to the front signal with my 2.1 receiver running speaker A and B plus the 15" Epik sub in one corner.
    The total number/size of 6.5" and 1" speakers with four monitor 70s (16 and 4, respectively) will be equivalent to that with two of the giant SDAs. So any way you look at it, I'll have a lot of great sound to fill the room. My guess is there will not be a dead spot anywhere.
    Living Room system: 52"HDTV, 4 Mon.70s, Epik Valor, Outlaw RR2150
    Bedroom System: 2 Mon.60s,Velo VRP1200, HK3490
  • ph0rk
    ph0rk Posts: 14
    edited June 2009
    Depends on the speaker - if it is a nearfield-capable two-way, then very close (on a desktop, like my VR-M60's). If it is a multi-driver or quasi-three way like my Monitor 70's, around 8' or more.
    I'd prefer to be a bit closer to 10', but my condo's living room won't allow it. Hell, I'd like for a few feet of room behind them while I'm wishing.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2009
    The center of my chair is 9ft, 7 and 3/8" from the speakers with the seat cushion split by the center point of the speakers which are exactly 9ft apart and toed in at 13.80 degrees, the speakers are exactly 4ft from the sidewalls and 5' 11 and 1/4" from the backwall at the closest point. The back of my chair sits 22.5" from its backwall.
    There is only one chair in the room. Like Thorogood I Prefer to Drink Alone. On ocaasion a fellow member comes over for a listen, I give my guests my chair, I sit on a hard wooden spindle chair I move in so as not to get to comfortable and watch them to make sure they dont move my listening chair, I used to leave them alone in there when I would get them a drink, till one time when I waited just outside with the Loft Room door slightly cracked, I could just see in and saw my chair move and the pre-remote was used.......................I thought I was going to die. But fortunately I did not.
    RT1
  • rru2s
    rru2s Posts: 90
    edited June 2009
    I am really digging the sound of my 4 monitor 70s plus a sub in the corners of my 24 x 15.5 foot living room.
    There is an immediate, next-to-the-stage ambience/presence no matter where you are since you will always be close to one left channel and one right channel. There are no spots with reduced volume anywhere in the room.
    Furthermore, exactly in the center of the room plus or minus 3 feet any direction every speaker hits you with the exact same travel time, in the same phase, and focused directly on you, so it gives the impression that you could hear a whisper from the recording stage.
    Also, when you move back about 4 - 6 feet or forward 4-6 feet longitudinal from the room center you get a very subtle reflective difference in front versus rear and that creates a concert hall type of effect. Plus, the sub seems to move with you to any seating position - it seems invisible yet everywhere.
  • ND13
    ND13 Posts: 7,601
    edited June 2009
    Modded CRS+s are 7ft apart and when I'm having a critical session, I sit about 8-9ft from them.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
