Which DAC should I buy?
Big Dawg
Big Dawg Posts: 2,005
edited December 2009 in Electronics
An Onkyo universal DVD has just fallen into my hands and is on its way to me (DV-SP504). I want to get a DAC for it. I've narrowed the choices to the following (although I am open to similarly priced options):
used Parasound DAC-2000 $300
new Little Dot DAC - $250-300
new Musical Fidelity V-DAC $300
used Adcom GDA-6000 $100-150.
Anyone have experience with these? I'll need to buy without listening, although if I buy one of the used pieces it should be minimal risk.
Also, any recommendations as to which digital connection might give the best result?
Thanks!
Post edited by Big Dawg on
  • thsmith
    thsmith Posts: 6,082
    edited June 2009
    Here is a few on AUdiogon if you could stretch your budget a bit. Try making an offer, you have nothing to lose.
    http://www.audiogon.com/cgi-bin/cls.pl?dgtlconv&1250127031&/Cambridge-Audio-DAC-Magic
    http://www.audiogon.com/cgi-bin/cls.pl?dgtlconv&1250260059&/Muse-Model-2
  • Big Dawg
    edited June 2009
    Lasareath wrote: »
    Hey Dawg,
    Have you seen this site?
    http://www.obadimports.com/page/page/4377355.htm
    Sal
    Sal,
    Have you used any of those before? Any recommendations?
    Mike
  • Big Dawg
    edited June 2009
    thsmith wrote: »
    The DAC Magic looks interesting - is it much better than the ones I've identified?
  • venomclan
    venomclan Posts: 2,467
    edited June 2009
  • wizzy
    wizzy Posts: 867
    edited June 2009
  • wizzy
    wizzy Posts: 867
    edited June 2009
    thsmith wrote: »
    Note you can buy a brand new DACMagic with warranty from spearit for $429, which is only about $40 more than the A'gon listing by the time you add S/H
    W
  • nguyendot
    nguyendot Posts: 3,594
    edited June 2009
    I'm aiming for the V-DAC, though it's a bit ugly.
    Main Surround -
  • ward91
    ward91 Posts: 338
    edited June 2009
    i know the cambridge dac is supposed to be good ;
    http://www.cambridgeaudio.com/summary.php?PID=320&Title=DacMagic
    look at the review page
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • debussyj
    debussyj Posts: 198
    edited June 2009
    I own both the PS Audio DL III and just picked up the Cambridge Dacmagic 2 weeks ago. I'm using the Dacmagic in my HT system and so far I really like it. I think it produces a nice across the board sound and I love playing with the different settings. I got a nice price for it on Audiogon. You should take a look there. My only negative is the unit physically gets hot when in use. Even hotter than my Mac Mini computer/server. I have a well ventilated cabinet too. I've been experimenting with sorbothane isolation feet to elevate the unit and get more air flow and that helps. Good Luck!
    heiney9 Posts: 25,411
    edited June 2009
    The Adcom GDA600 will surprise you. If you are looking for a more open, analog sounding DAC this fits the bill. The newer inexpensive DAC's all seem to have that analytical, digital sound. Never been a fan of Wolfson DAC's.
    FWIW
  • strider
    strider Posts: 2,568
    edited June 2009
    heiney9 wrote: »
    FWIW
    So far the Pacific Valve Fathom I just got is anything but analytical. Non oversampling, eight TDA-1543 chips. I only have about four hours on it, though, so take my comments with a grain of salt for the time being.
    Wristwatch--->Crisco
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2009
    If you need another option, I have an older Theta DAC (Pro Progeny) I could let go for around $300. It retailed for $1200 a few years back and still looks and sounds great. I've used it with a bunch transports / players over the past few years and thought it improved the sound quality of each one.
    http://www.polkaudio.com/forums/showthread.php?t=77585
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • toobwacky
    toobwacky Posts: 30
    edited June 2009
    You might consider a Sony EP9ES. They can be found used between $100 and $150.
    Not only is it a really good DAC, but a comprehensive processor that will give you volume, balance, quasi parametric EQ and, if you want it, surround sound processing all remote controllable.
    I am so impressed by its sound and capabilities, that I bought 3 (2 are stored as back-ups) because I never want to be without one. BTW, I use it mostly for 2 channel music listening.
  • Systems
    Systems Posts: 14,873
    edited June 2009
    If you can snag a 600 for less than $200 I doubt you will be disappointed and the V-DAC at $300 looks interesting, at least on paper.The 600 uses what was then Burr Browns best dac chip the PCM63's which was the chip of choice for most of the hi end DAC's in the 90's.The all important analog stage is biased into class A (and directly coupled) aswell it has separate power supplies for the digital and analog sections.All in all a nice piece for what they can be had for.
    The V-Dac uses Burr Brown's newer generation DSD1792 which is now one of the most widely used dac chips used in hi end CDP's and DAC's .It also incorporates a sample rate converter which not only upsamples the data, it reduces jitter.Unfortunatly I can't find any details about the analog sections design or the op amps they are using.For $300 it's may be a sleeper.
    Testing
    Testing
    Testing
  • nspindel
    nspindel Posts: 5,343
    edited June 2009
    I just got the Little Dot DAC and am EXTREMELY impressed. For the money, I don't see how this can be beat.
  • mizthuphee
    mizthuphee Posts: 55
    edited June 2009
    hi all, does anybody in the forum have any experience on this dac? http://stores.shop.ebay.com/Vintage-Audio-Lab_Digital-to-Analog-Converter_W0QQ_fsubZ225604719QQ_sidZ314713499QQ_trksidZp4634Q2ec0Q2em322#item3ef55d9964
    I was contemplating on V-DAC, Beresford TC 7520 & Musiland MD10 but I bumped into this. The reviews are very intriguing, checkout Audiogon: http://forum.audiogon.com/cgi-bin/fr.pl?rdgtl&1227383057
    Even Steve of Empirical Audio said "It is great sounding with a low-jitter input" and for modders, he recommended..."3.3uFd V-Cap oils bypassed with .22uFd Sonicap Platinums. These require some weeks of break-in BTW. This will be a world-class DAC with these caps. Not as good as my Overdrive, but beating most DAC's in the $10K range"
    HT / 2 Channel combo system:
    LSi9 (xo modified by Face), LSiC, LSi-FX
    Mac mini 2010 boot up in 64 bit kernel (2.66 GHz 8GB RAM,60 GB SSD)>itunes> 2TB mini Stack v3>Pure Music>W4S DAC2>Conrad-Johnson PV14>W4S SX1000
    oppo BDP 85SE
    Onkyo TX-SR876
    Emotiva XPA-5
    HSU VTF-1
    Samsung LN4095D
    MIT S3 speaker cables (LR & C) & interconnects
    MIT EXP 2 (L & R surrounds)
    Pangea PC A-9's and A-14SE's
  • kolyan2k
    kolyan2k Posts: 259
    edited June 2009
    mizthuphee wrote: »
    same design as DAC-AH from Pacific Valve
  • concealer404
    concealer404 Posts: 7,440
    edited June 2009
    debussyj wrote: »
    Extremely stupid question.... could you explain how the DAC is used in an HT scenario?
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2009
    GV#27,
    I went with your suggestion, and ordered a Bryston BDA-1. I was told it would take a couple of weeks since Bryston hand builds each unit, and tests it, before shipping. I am looking forward to hearing how it compares to the Benchmark Dac1 Pre it will replace.
    Thanks for the recommendation.
  • Systems
    edited June 2009
    Well it would have to be 2 channel PCM because it can't decode Dolby Digital or DTS datastreams.
    Testing
    Testing
    Testing
  • Systems
    edited June 2009
    BlueFox wrote: »
    GV#27,
    Hey Congrats and your welcome. I'm envious.Those are two heavy hitters so it will be interesting to get your feedback on that comparison.
    Testing
    Testing
    Testing
  • debussyj
    debussyj Posts: 198
    edited June 2009
    I'm basically using the Dacmagic for 2 channel listening with my Marantz receiver. I'm not using the onboard DAC of the Marantz for 2 channel. I have it connected to my Mac Mini computer, which is loaded with AIFF music files. I like having the ability to store lots of tunes in one place and use my Itouch as a remote control to play DJ. I also use it with my multi-room outdoor speakers as the only way to connect a device for multi-room is via analog. It works/sounds pretty good this way. DJ
  • debussyj
    debussyj Posts: 198
    edited June 2009
    Hey Bluefox (Bud),
    The Bryston has always intrigued me and was one of my first choices for DAC in my serious 2 channel room. From what I've heard, it blows away the PS Audio (without mods) and Dacmagic for sure. The only drag is, it isn't cheap. Let me know what you think of it. DJ
  • BlueFox
    edited June 2009
    Colleen/GV#27
    I will be more than happy to give my opinion of the Bryston, and how it compares to the Benchmark. Price wise it was only a couple of hundred more than the Benchmark at a shop I found online. So, even if it is only a little better than the Dac1, I will not have too much buyer’s remorse. :)
  • POIDOG
    POIDOG Posts: 391
    edited June 2009
    mizthuphee wrote: »
    Yes. I recently purchased and paired it with a Sony SCD-CE775 and it greatly opened the sound stage and the Sony became less muffled. The design is very similiar to the PV Fathom. Would give the edge to the PV, however, the Valab price was too good to pass. ;)
    Bill
  • mizthuphee
    edited June 2009
    Bill,
    thanks for the reply. just curious, has the Valab been burned in? from what i've read, it need at least 200 hours to burn it in? it'll be interesting if your opinion will change when it is completely burned in. if you find time to post your observation, i'll appreciate it.
    Pat
    oppo BDP 85SE
    Onkyo TX-SR876
    Emotiva XPA-5
    HSU VTF-1
    Samsung LN4095D
  • POIDOG
    POIDOG Posts: 391
    edited June 2009
    mizthuphee wrote: »
    Bill,
    Pat
    Yes, I burned it in 24/7 for a week. Vintage Lab recommended 3 days. As time went by I began to pick up nuances never heard in my music before. Wait a minute those are the voices in my head :confused: Sorry, just kidding.
    The bass is definitely tighter. Again, I think the PV Fathom has an edge, but not by much, especially when you consider the slight cost difference.
    By the way I had to send the Fathom back, which is why I ended up with Valab. $200.00,free shipping, had in 3 days. :cool:
  • debussyj
    debussyj Posts: 198
    edited June 2009
    Hey Bluefox (Bud),
    So how's the Bryston working out for you? Any initial impressions?
    DJ
  • george daniel
    george daniel Posts: 12,096
    edited June 2009
    I just found a minty Adcom GDA 600for 100 smackers,,should be here in a day or two. I'm happy with that deal.
  • Big Dawg
    edited June 2009
    Did you buy that on eBay? I saw a minty one there just too late for $100....
    I'm jealous, but at least a Polkie got it.....
