How can the power output exceed the power input????
ward91
ward91 Posts: 338
edited June 2009 in Electronics
Hello all, i have wanted to know this for a while , some of the avr’s on the market have rated power outputs (continuous or rms) that are more than the rated power input in watts , how is this ??
For example i have a borrowed denon avr 1509 and the rated power input in watts is 360 . and the sums rated power outputs are (75w*5ch) = 375w @ 8ohm . or (110w*5ch)= 550w .
How can this be ??
Cheers ed :-)
ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
Post edited by ward91 on
  • bobman1235
    bobman1235 Posts: 10,822
    edited June 2009
    Two things.
    One, usually "75w x 5ch" is with only one or two channels driven. It's a cop-out, and blatantly dishonest, but almost all of them do it.
    Two, for instantaneous power, you could technically exceed the input power thanks to capacitors and whatnot.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited June 2009
    Bobman, "If this is true, which 2 channels would get the main power?
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Jim Shearer
    Jim Shearer Posts: 369
    edited June 2009
    I think the trick is to understand the ratings used. I could be wrong, but most AVRs aren't rated for full output with ALL channels driven. I.e., the fronts may be driven at that level, but the surrounds are at much lower levels. If all channels drew 'full power' continuously the power supply would obviously not be able to deliver.
    Then there is the difference between rms continuous power (based on simple sine wave at a specific frequency) and music power (which is a more complex signal with transients that are significantly greater than the average power draw.) With a well designed amp, there are reserves in the PS which will allow the amp to deliver clean transients that are perhaps 5 times the level of the rms continuous power rating.
    It get really complicated!
    Cheers. Jim
    A day without music is like a day without food.
  • bobman1235
    edited June 2009
    I don't understand the question....
    Basically, the rating is saying that if you have all five channels connected but only one or two are being driven, you will get 75 watts on those channels. If you are driving all five you'll get significantly less on all of them. I don't believe there's any kind of "priority".
  • lanion
    lanion Posts: 843
    edited June 2009
    A more legitimate way is that amps use large capacitors. Some expensive power supplies / surge protectors have giant coils that allow for up to 50 amps of current... now this can only be used for a very short period of time as the capacitors will run out and then recharge.
    It is possible for output to exceed input in short bursts.
    My Iron Man training/charity blog.
    HT:
    32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
  • Knucklehead
    edited June 2009
    Bobman, Thanks I think I understand now, forgive me for the dumb question, Im still learning.......If im watching a movie in DTS or DD and all 5 channels are being driven with my Pioneer 816 rated at 110 wpc I may only be delivering half that amount to all 5 channels....am I on the right path?:)
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • bobman1235
    edited June 2009
    Yes sir, that's about it. Luckily, chances are you're RARELY driving all five speakers at once.
  • Knucklehead
    edited June 2009
    Thanks, I understand the use of seperate amps a little more now, and whadda ya know, I have pre-outs.:D
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • ward91
    ward91 Posts: 338
    edited June 2009
    The guy at denon said that “mains is different” and the amp does give the specified power to all channels driven . still none the wiser
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • RandyBox
    RandyBox Posts: 125
    edited June 2009
    So the answer is "It can't..." or did I miss something?
  • nguyendot
    nguyendot Posts: 3,594
    edited June 2009
    Didn't one manufacturer have 'power steering'?
    Main Surround -
  • speakergeek
    speakergeek Posts: 555
    edited June 2009
    RandyBox wrote: »
    Nope, you are correct. Receivers are not rated for 5 or 7 channels driven simultaneously, only 2.
  • Marty913
    Marty913 Posts: 760
    edited June 2009
    nguyendot wrote: »
    Yes, the Carver AV-705x 5-channel amp has it. There may be others.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • ward91
    ward91 Posts: 338
    edited June 2009
    well , my normal amp the Cambridge 540r has specs for all channels driven but the L/R power is higher if only L/R are driven. (limitation of continual psu output ?)
    "80W per channel @ 8 Ohms all channels driven/100W per channel @ 8 Ohms 2 channel ".
    and the power consumption is higher than the output. at 850w .
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • bobman1235
    edited June 2009
    xcapri79 wrote: »
    The efficiency cannot be more than 100%. Perpetual motion machines don't exist.
    http://www.hulu.com/watch/21710/the-simpsons-stir-crazy-kids
  • speakergeek
    edited June 2009
    ward91 wrote: »
    Should have qualified my post by saying "generally". There are a small hand full of receivers out there actually rated for all channels driven simultaneously, but the common four (Onkyo, Denon, Pioneer, and Yamaha) don't rate all channels simultaneously, only two at a time.
