Monitor 30 connection question from idiot newbie...
sfeller
sfeller Posts: 2
Just wondering which rear terminal set is the correct one to use when NOT bi-wiring? I assume the top set is higher frequencies and the bottom is bass when bi-wiring. But which one is better to use when leaving the connector plate in?
Post edited by sfeller on
    treitz3 Posts: 19,974
    edited June 2009
    Either one and you'll be ok. Enjoy the music.
  • nguyendot
    nguyendot Posts: 3,594
    edited June 2009
    With the metal jumpers in place, it won't matter which you hook it too since the signal will flow to both...
    Main Surround -
  • sfeller
    sfeller Posts: 2
    edited June 2009
    Thanks. Just wanted to make sure that it didn't make a difference. The manual wasn't clear.
  • ChrisD
    ChrisD Posts: 101
    edited June 2009
    I've heard putting it in the top one makes treble clearer, but it sounds like a myth.
  • nguyendot
    edited June 2009
    ChrisD wrote: »
    So putting it in the bottom one will give better bass? Lol
    Main Surround -
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2009
    Put the positive in the top and the negative in the bottom. That way you'll get clearer bass and clearer highs.:p
    Seriously though...it makes no difference. Either pair is fine.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
