An Elegant solution to a nasty problem
nooshinjohn
I have been wracking what is left of my only remaining brain cell trying to find a better solution for placing my turntable in my system, as The last place I wanted it was on top of my Sunfire amp, and there was no more room at the in for it in my audio rack. What I came up with was using three pieces of polished quarter inch glass joined together so that I could make a shelf above the Sunfire. I have two inches of clearance all around the amp and a stable platform for the turntable over the top of the amp.:)
I am pleased with the results and thought I would share....
Post edited by nooshinjohn on
Looks good, does the amp get hot or the turntable rumble or anything ?
They are shelves that you mount to the wall specifically for TTs.Speakers: SDA-1C (most all the goodies)
I have no trouble with heat dissipation from the Sunfire, and no rumble from the table. It seems to be a pretty solid platform. I though about the wall mount alternative, but it would have been more expensive and an easy place for my cat to find a new place to take a nap. Secondly, I thought about vibrations coming from the walls at higher listening volumes.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Very nice job. Looks great.engtaz
Looks very nice, are those connectors extruded aluminum? Where did they come from?
yes they are.. I got them thru the glass shop that cut and polished the glass.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Nice solution, John. How did you polish the glass corners and the sides? Would thicker Plexi-glass could work better for this purpose?
Edit : Ok, I read the post above which just happened to arrive before mine. So, I know you got it done at the glass shop. My bad!Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Now that's what I call creative thinking! Good job.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Looks nice John!The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
