An Elegant solution to a nasty problem
nooshinjohn
nooshinjohn Posts: 25,990
edited June 2009 in DIY, Mods & Tweaks
I have been wracking what is left of my only remaining brain cell trying to find a better solution for placing my turntable in my system, as The last place I wanted it was on top of my Sunfire amp, and there was no more room at the in for it in my audio rack. What I came up with was using three pieces of polished quarter inch glass joined together so that I could make a shelf above the Sunfire. I have two inches of clearance all around the amp and a stable platform for the turntable over the top of the amp.:)
I am pleased with the results and thought I would share....
Post edited by nooshinjohn on
  • thsmith
    thsmith Posts: 6,082
    edited June 2009
    Looks good, does the amp get hot or the turntable rumble or anything ?
    They are shelves that you mount to the wall specifically for TTs.
    edited June 2009
    I have no trouble with heat dissipation from the Sunfire, and no rumble from the table. It seems to be a pretty solid platform. I though about the wall mount alternative, but it would have been more expensive and an easy place for my cat to find a new place to take a nap. Secondly, I thought about vibrations coming from the walls at higher listening volumes.
  • engtaz
    engtaz Posts: 7,669
    edited June 2009
    Very nice job. Looks great.
    engtaz
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited June 2009
    Looks very nice, are those connectors extruded aluminum? Where did they come from?
    edited June 2009
    yes they are.. I got them thru the glass shop that cut and polished the glass.
  • megasat16
    megasat16 Posts: 3,521
    edited June 2009
    Nice solution, John. How did you polish the glass corners and the sides? Would thicker Plexi-glass could work better for this purpose?
    Edit : Ok, I read the post above which just happened to arrive before mine. So, I know you got it done at the glass shop. My bad!
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2009
    Now that's what I call creative thinking! Good job.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2009
    Looks nice John!
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
