Sealed vs Ported Subs
So what's the verdict on sealed vs ported subs? Does one perform better for music vs HT? Does one fill a room better than the other/a greater thump to the chest. Does one have a faster response than the other, etc, etc??? As always, looking forward to everyone's opinions and experience. I have a large room to fill, 600 sq ft. Thanks
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
Denon 3800
Parasound HCA-2205A
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Post edited by mufsoman on
It's all in the design. Sealed generally has tighter bass but diminished output.
Ported generally has a +3db boost at a given tuning frequency (of the port).
All this means nothing if it's not designed correctly.....
Read some reviews and you will see what works better. My dad has the PSW1200 (the gigantic one) and its bass is awesome for movies (bottom power port) but I feel it leaves something desired for music. I have the PSW150 (i thought it was a 200) and I love how punchy it is, but for 600sq ft it wouldn't even put a dent in a room that size.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I tend to like sealed, however I will say that my Snell (ported) doesn't sound like many ported subs. There is a lot of research that goes into a good ported sub.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
