Just Inherited a pair of Polk Audio 10a Monitors. Peerless Tweeters.
AriusVision
AriusVision Posts: 13
edited August 2009 in Vintage Speakers
I just inherited these Polk 10a monitors from my parents. They wanted to give them away, and after a little research online I decided that I would take them. I believe that they have the peerless tweeters.
I know everyone has seen them before...but here they are:
They are fairly dirty, I will need to give them a nice clean.
I plan on re-doing the XO with Dayton caps and Mills resistors. From what I've seen in the shootouts, the Daytons are the best on a budget. Maybe someday I will upgrade to Sonicaps but for right now I don't plan to.
(4) 12uf Dayton Caps (~$20)
(2) 34uf Dayton Caps (2x 18uf + 2x 15uf) (~$21)
(2) 2.5 ohm mills resistors (?)
(2) 2.7 ohm mills resistors (?)
For the resistors what is the difference between the MRA-5 and the MRA-12?
http://www.soniccraft.com/mills_resistors.htm
I was thinking of going MRA-12 just as a precaution, will this make any difference in sound quality?
Thanks for taking a look!
Post edited by AriusVision on
  • danger boy
    danger boy Posts: 15,722
    edited June 2009
    hey congrats.. you're parents have good taste.. this is the kind of hand me down I like. LOL
    yeah clean them up.. this one looks pretty good condition to me. they look to be early Monitor 10's. nice that is has the peerless tweeters.
    PolkFest 2012, who's going>?
    heiney9 Posts: 25,497
    edited June 2009
    Welcome to CP. Nice speakers! Fun project too. The MRA-5 and MRA-12 refer to the wattage rating of the resistor. Go with the 12. Not sure you'll hear a difference between the 2.
  • geppy1
    geppy1 Posts: 3,076
    edited June 2009
    Those look like mine. Monitor 10s Are they real walnut cabinets. Mine are (just beat up) What are the serial numbers on the tag on back?? Can you get me a picture of your croosover before you take it apart?? I suspect the tweeters are the orignal HF 1000 Peerless made in Denmark. The later 10a tweeters were Peerless made in the US for Peerless. They are probably 1979 to around late 1980 early 81 Keith
  • skrol
    skrol Posts: 3,460
    edited June 2009
    What is the differences between the ones made in Denmark vs the USA?
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • zingo
    zingo Posts: 11,258
    edited June 2009
    If you are using Mills resistors, I would use the MRA-12 as you will want the higher power rating. Most stock XO resistors are rated for around 10w.
    I would also consider Mundorf resistors. I originally bought them because they were cheaper than the Mills ($2.50 each), but ended up keeping them because I think they sound better. :)
    edited June 2009
    zingo wrote: »
    That's good to know because Madisound sells the Clarity caps I want to try and they sell Mundorf resistors not the Mills. This way I only pay shipping to one company.
    I'm thinking of getting rid of the Solens on the high pass of my 5B's and then putting the proper resistor value in using a Mundorf. I have Mills now 2.0 ohm it really should be 2.7 ohm. I think it will blend the RD0's slightly better.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    Welcome to Club Polk AriusVision. Those are nice speakers.
    edited June 2009
    Great Way to Break into the Club Arius--with a vintage Peerless!
    Welcome to CP! You're way ahead of the game with those in YOUR FIRST POST!!
    cnh
  • engtaz
    engtaz Posts: 7,669
    edited June 2009
    Congrats on the 10's. Sweet.
    engtaz
  • AriusVision
    edited June 2009
    Thanks for all the welcomes everyone!
    Both pictured, cleaned them up some. Could use more will do that another time.
    Geppy1 - Here is the serial:
    The other is just 2 less.
    The XO untouched. Stock.
    Zingo - Thanks for the advice. I sourced the 2.7 ohm resistors in the Mundorf flavor but am having trouble finding any 2.5 ohm ones. Are you just using 2.2 ohm resistors in place of the 2.5 ohm ones?
    Thanks again for all the warm welcomes! I will take many pictures when upgrading the XO for future reference.
    Forgot to add, what receivers are recommended for these speakers? Not looking to spend much.
  • geppy1
    geppy1 Posts: 3,076
    edited June 2009
    It amazes me how screwy the model and labeling system was back then. My RTA 12Bs were done in April of 84 yet I found a pair of RTA12Cs done in January of 84. Four months BEFORE the Bs Now here is another example. Your 10As are serial 68000 and from August of 79. Mine are 10s serial 72178 and from Nov of 79. We have 10As before 10s. I wonder if your tweeter is marked 7514____ (Denmark) or 5514___ (US made). My brothers 10As are from 1983. By the way my croosovers was redone by Ken (the MAN) at Polk about 12 years ago. Assuming mine looked like yours at one point I wonder(for educational reasons) what the differences are. Great speakers keith
  • geppy1
    geppy1 Posts: 3,076
    edited June 2009
    Here is the picture
  • Mos Fete
    Mos Fete Posts: 8
    edited June 2009
    The Monitor Series are amongst my favorite Polks, I have two pais of the 5's, one pair of 7's, one pair of 10's and one pair of RTA-11T's.
    You really lucked out with that inheritance.
    Enjoy.
  • george daniel
    george daniel Posts: 12,096
    edited June 2009
    congrats on the speakers,, now what are you going to power them with?
  • AriusVision
    edited June 2009
    Thanks, not sure what I will power them with, any ideas? I searched a bit but couldn't find any amps/receivers that people are using with these in my price range. I might just see if my parents have the old amp that they powered it with.
    Forgot to answer the question on the wood. It is laminated wood, still looks very nice though after a good wood oil polish, has a nice cherry accent to it. :)
    I might just go with Mills Resistors to get exact values instead of the Mundorfs.
    I cleaned the speakers with windex, from what I have read it is fine as long as it is in moderation. Now they really look nice. Thinking of getting some black wet look paint to put on it not sure though.
    I will check out the tweeter number later tonight.
  • AriusVision
    edited June 2009
    Update:
    I am being offered a Pioneer VSX-9500S for 40+ shipping that I can fix up. Or I have an older NAD 7045 receiver in my possession that works fine. I'm not sure if the switch is worth it...any thoughts?
    Edit: Forgot to mention I got in the parts today, starting work on the Monitor's soon.
    Tony M Posts: 11,725
    edited June 2009
    I wouldn't use paint on those:eek:. Keep them original!!! they're classic....
  • AriusVision
    edited June 2009
    Installed the new Crossovers, pretty easy install. Sound and work great. Unfortunately I did not test these speakers before hand and one has a blown tweeter.
    The good news is that I went on Ebay and found two peerless tweeters for the Polk 10a that were made in Denmark. :)
    Here are pictures of the new caps on the board.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2009
  • hearingimpared
    edited June 2009
    Nice work however I have one suggestion; get the hot glue off of the Mills resistors in that it will make them overheat.
  • AriusVision
    edited June 2009
    Thanks I will do that when I replace the tweeters.
  • RandyWilliamson
    RandyWilliamson Posts: 178
    edited June 2009
    Lucky you ..on those peerless tweets...get a reliable amp....something solid to drive them with...trust me you won't regret it and you won't pop your fuses or tweets.....
    Congrats!
    Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
    Benq W5000
    "Leaning back like a maxwell tape commercial listening to pure polk bliss"
  • Mother Mooch
    Mother Mooch Posts: 129
    edited June 2009
    Nice speakers and nice clean up job...
  • hearingimpared
    edited June 2009
    Lasareath wrote: »
    LOL!!! Joe, he joined 1 month before you! :D
    With six posts he gets a new welcome.:p
  • AriusVision
    edited June 2009
    Found out the problem was not my tweeters...I spent so much time focusing on the Crossovers I missed checking the fuse! The fuse on the speaker where the tweeter wasn't working was bad...hence the mids/lows were working but the highs were not.
    While it was stupid to overlook such a crucial thing, I'm not too mad as it did lead me to these Danish babies:
    The original Peerless tweeters I will let go for $60 shipped by Paypal. (Not the ones pictured above) PM if interested. I will also make a sale thread in a couple days or so, want to give those following the thread the first opportunity though.
  • geppy1
    geppy1 Posts: 3,076
    edited June 2009
    What is the number on the back of your original tweeters 5514---- or 7514
    ? The 7514---- will sound more like the ones above as both are made in Denmark. Tweeters marked 5514---- were nade in the US for Peerless and sound slightly different. Most people assume any vintage Polk Peerless is the same as any other and do not realize there are two different ones. keith
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2009
    It's easy to tell the difference between the Peerless tweet's even without model numbers.
    Here's a pic of the American Peerless tweeter. Note the small hole in the center of the dome. This supposedly relieves the tension on the dome, and gives it a slightly smoother sound.
    [URL="[IMG]http://i715.photobucket.com/albums/ww160/comfortably_curt/peerless_2.jpg[/IMG]"]peerless_2.jpg[/URL]
    The Denmark Peerless tweeter lacks this hole in the dome. Whether or not it sounds better, I can't say, as I've never heard the Denmarks. I've heard that they do sound different/better though. I'd like to get a pair of the Denmarks to make a comparison sometime.
    Arius-Just so you know, as per forum rules, you're required to have at least 25 posts before selling anything on the forum. You seem to mean well though.
    Stick around and contribute for a while, and then throw those tweets up in the FM if you still want to move them along. I'm sure you won't have much trouble finding a buyer for them.;)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • AriusVision
    edited June 2009
    Oh, I did not know that! Thank you ComfortablyCurt for letting me know.
    So the American made sound better than the ones made in Denmark?
  • comfortablycurt
    edited June 2009
    Like I said, I've never compared the two, so I can't really say. Better is kind of a subjective term, but from everything I've ever gathered, it's not so much that it sounds "better", just a bit "different".
    Like I said, I'd like to compare the two sometime myself. Since you're going to have a pair of each, and take some time to compare the two. You may prefer one over the other. When/if you decide you prefer one type, you won't have much trouble moving the other pair. The Peerless tweets are pretty desirable, whether it's the American or Denmark version.
  • geppy1
    geppy1 Posts: 3,076
    edited June 2009
    The ones made in Denmark that Polk used from around 1977 to about 1980 also have the hole. Polk put it in. The only ones that do not have the hole are the non originals or aftermarket replacements. (You could actually get the ones made in Denmark up until about 7 years ago when the tooling cracked and broke, game over) The original was called an HF1000. The later American made (Peerless (1980 to about 1983) were actualy called SL1000s in the Polk brochure and pictured as such. As we know around 83 and into 84 the change over happened to the silver colored faceplate and clear dome and that also became the SL1000. I myself have no real problem with the silver faced SL1000s.If in good shape they are very silkey and pretty matural sounding. The SL2000s on the other hand sound like timfoil(my wifes thoughts)
