new to car stereo's, will this setup work?
the von
i'm extremely new. i've tried researching on the internet, got some basic knowledge... just trying to get a sub in my car with sum decent bump. my speakers are fine in my stock honda accord, but should i upgrade? these are the speakers i'm considering....
http://www.newegg.com/Product/Product.aspx?Item=N82E16882647036
Also this amp with this sub
amp.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882863054
sub.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882863059
i know they arent name brand... but for the price.... can't beat it.... but i will also need a box for the sub....
so theres the possibility of going with the deal at crutchfield
sub.
http://www.crutchfield.com/p_236T4510/MTX-Thunder4500-T4510-04.html?tp=111
and if i buy two... i get a free box for them.
but in the near future...[for a grad present] i am getting my girl a sub and amp. would i be able to do some changes to that box to separate it into two boxes? or am i crazy? i thank you guys in advance for the help!
amp.
sub.
sub.
Post edited by the von on
Welcome to the forum. We have a 'car audio' section, towards the bottom of the main page. You would be better off re-posting there.:)I refuse to argue with idiots, because people can't tell the DIFFERENCE!
I did car audio for a long time and you would do better if you went with the MTX's, they are much better subs and they will sound better. Not only that but you will be able to push them with more, a nice 200W mono amp or a 400x2 is all you need. I would get an MTX and have someone that knows what they are doing hook them up (not says they know what they are doing, really knows). They won't rock the block but they will sound very good. The Clarion's are good, just make sure you pair these speakers with something that's not Sony (they are horrible for car audio).
Don't cut the box in half...bad idea.Receiver: Marantz SR7002
Fronts: Canton Chrono 509 DC
Center: Canton Chrono 505 CM
Surrounds: Canton Chrono 502 SP
Sub: SVS PC12-NSD
TV: 40" 1080i JVC Multisystem LCD(upgrading to 50" Samsung LED)
Blu-Ray: PS3
DVD: Pioneer DV-420V (HDMI)(for PAL DVD's)
Audio/Music: MacBook Pro hooked up thru HDMI
Gaming: PS3 (oifvet0608) XBOX 360 (JAYtheVET)
Cables: Inakoustik Reference
