Toshiba 36"HDTV question
mccarts747
mccarts747 Posts: 48
edited August 2003 in Electronics
I'll preface this by saying, I haven't had time to really research the problem. I thought I would see if anyone else may have run into this. I purchased my Toshiba 36" HDTV ready TV back in December. I have noticed recently while watching cable broadcast, digital and now HDTV broadcast there is a high pitched noise coming from the back of the TV (note this sound is not coming from the speakers). Sort of like a dog whislte. It's quite annoying. Although , it is inconsistent. I haven't been able to figure out what makes it happen. It randomly happens and then goes away. My theor is it has something to do with the cable broadcast although I haven't had time to test out the DVD player and VCR inputs for this yet.
Any help/suggestions would be appreciated.
Thanks,
McCarts
Shawn
___________
Onkyo TX-NR609 (receiver)
Sony Blue ray Player
Sony 46" LCD TV
Comcast HDTV X1
VM10 (Center)
VM10 (Front Mains)
FXi30 (surrounds)
Cambridge Soundworks Cube8 (sub)
Post edited by mccarts747 on
  • hoosier21
    hoosier21 Posts: 4,420
    edited August 2003
    I would not care what the problem is, I would return it for another one, sound like something is wrong.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • BeginnersLuck
    BeginnersLuck Posts: 213
    edited August 2003
    Simply returning the unit might not fix the problem. So I would first try and do some troubleshooting to see if you can pin-point before returning the T.V...
    There are other variables that might be casuing this problem.
    Try seeing if the noise goes away on different sources, then maybe try hooking up a different T.V. to see if the hum still exists.
    Good Luck,
    -BL
    TWFTPQ
    Receiver: Outlaw 1050
    Amps: Outlaw M-200 x 3 (Powering Mains and Center)
    Mains: RT800i; Center: CS400i; Surrounds: F/X500i
    Sub1: 214L Vented Tempest
    Sub2: 122L Sealed Tempest
  • hoosier21
    edited August 2003
    DOUBLE POST SORRY
